broke the sway bar nut inside the frame
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WABOOM, Mar 26, 2012.
  1. Mar 26, 2012 at 8:09 PM
    WABOOM
    WABOOM [OP] Well-Known Member
    Minnesota yeah sure ya betcha
    2013 F-150 XLT Supercrew 4x4
    debadged
    I was disconnecting the sway bar bracket in my 2007 Tacoma and the nut that is welded inside the frame broke loose. What can I do now? (the bolt is turning free because the welded nut is now loose)
  2. Mar 26, 2012 at 8:10 PM
    jandrews
    '09 FourDubDee TRD OR
    grinder --> cutting wheel --> No problem!
    txtaco87 likes this.
  3. Mar 26, 2012 at 8:11 PM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    TBD
    sway bar? whats that :D
    11Bguy likes this.
  4. Mar 26, 2012 at 8:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Take it to a body shop, or fab shop, and see if they can get access to re weld it in place.
  5. Mar 26, 2012 at 8:23 PM
    NE Taco
    NE Taco Member
    Boston, MA
    06 BSP TRD Sport AC 4x4
    Bilstein 5100's at 1.75", 2"AAL, GrillCraft, Leer 100R(winter only), Foglight anytime, AVS in channel visors,
    Same thing happened to me a couple years ago. I cut the bolt with a whizzer wheel, then I pulled the front bumper cover and then pulled the bumper off as well. With the bumper off I was able to reach into the frame with a breaker bar and place nut over the hole and simply nut and bolt the swaybar back into place. Kind of a pain, and it will be if I ever need to remove the sway bar again, but it was the only thing I could think of at the time. Since then I saw sway bar relocate kits. I figure if I had nut and bolted one of those in I would be able to remove the swaybar in the future without removing the front bumper. If I ever need to remove it again I will add a relocate kit.
  6. Mar 26, 2012 at 8:29 PM
    NE Taco
    NE Taco Member
    Boston, MA
    Chris, No access to the frame there. It is fully boxed in that section. Only way would be to cut an acces hole and then patch it up. There's no way I'm having my frame cut into. I thought about using a rivnut, but ultimately decided I did not trust the strength of it
  7. Mar 26, 2012 at 8:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is how you gain access VVVVVV
  8. Mar 26, 2012 at 8:45 PM
    NE Taco
    NE Taco Member
    Boston, MA
    Good luck getting a welder that far down the frame through the front bumper mount, let alone being able to make an accurate weld with no visual....
  9. Mar 26, 2012 at 9:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You should be able to get it with a stick. And a couple nice little bugger welds would be more than adequate.
  10. Mar 27, 2012 at 4:35 AM
    jandrews
    Why are we even talking about putting the swaybar back on? No no no no no no no.
    ManBeast likes this.
  11. Mar 27, 2012 at 7:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Because, depending on the suspension, there is increased body roll when turning, and if a sudden evasive manuver is called on, the vehicle could roll over.
  12. Mar 27, 2012 at 4:04 PM
    jandrews
    Boo hoo. Roll it back over and keep driving.;)
    Silverspool likes this.
  13. Mar 27, 2012 at 4:06 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I've seen welds made from 4-5 sticks distance away (Yeah...4 sticks tacked together and then used to weld). Pretty...Not at all...Strong-as fuck.
  14. Mar 27, 2012 at 4:07 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    don't forget to call an amberlamps for the mother and child you took out while rolling over;)
  15. Mar 27, 2012 at 4:26 PM
    jandrews
    They should've run faster.
  16. Mar 27, 2012 at 4:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    10 points each
  17. Mar 27, 2012 at 9:16 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    I approve this thread! :cool:
  18. May 14, 2012 at 5:07 PM
    blacktaco07
    blacktaco07 Active Member
    Canada
    2007 4DR Tacoma TRD
    I know this thread is getting old but here's a few options. You can purchase threaded inserts and install the threated inserts with the special tool.
    The other option is to weld a piece of metal (tab) the same width as the nut but approximately 3 inches in length...it has to be longer than the width of the channel...you will understand shortly...
    Once the nut is welded onto the tab, tack weld a wire to the tab. Now you can put (fish) the entire nut/tab through the hole on the side of the frame and guide it to where the original nut was.
    The reason for the tab to be long is when you start to tighten the nut/bolt, the tab will hit against the frame and you will be able to tighten it up. Once completed, break the wire off the tab.
    Hope this helps, as it worked for me. Good luck
    shr133 likes this.
  19. May 13, 2017 at 7:37 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Really good idea sweet. I need to do this fix............
  20. Oct 9, 2017 at 3:10 PM
    RB825
    RB825 Member
    Randy
    11 silver DCSB TRD
    blacktaco07 I know this is super old but.. I had this problem and after a quick google search it brought me to this thread, and your idea worked great! Thanks! I actually wound up using a zip tie to get it aligned, I fished it down to the mounting point/hole, slid the zip through the nut and let it go, slid into place perfectly.
