broke the tip off my valve stem, curious on best way to replace this having a tpms sensor behind it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1YOTA6, Nov 13, 2016.
  1. Apr 29, 2018 at 9:02 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    A lot of aftermarket tpm sensors I use every day are rebuildable. Some oem ones are a single piece and if you break the stem you are shit out of luck. The rubber one as previously posted is usually only found in GM products. A sensor stem that is made out of aluminum must be replaced if damaged. They do make aftermarket sensors for our toyotas with the rubber “GM” style valve stems that secure the sensor via a small torx screw. I’ve put them in a few Toyota trucks myself.
  2. Apr 29, 2018 at 10:15 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I have no idea but it looks good in the Ad... I wish you well.
  3. Apr 29, 2018 at 6:29 PM
    Heliguy
    Heliguy Member
    Sean
    2017 TRD Pro Barcelona
    Thanks guys. I am actually really curious about this valve core replacement. Seems like it would be something handy to have in a pinch...sure would have been nice to have this weekend.
  4. Apr 29, 2018 at 7:17 PM
    Muddinfun
    Muddinfun Well-Known Member
    If you're a hard core wheeler and you want to have something in the glovebox to use in case of a broken valve stem, this seems like the hot ticket.
    https://www.colbyvalve.com/
  5. Apr 29, 2018 at 7:20 PM
    Heliguy
    Heliguy Member
    Sean
    Yep! Better than carrying a drill! Thanks!
    Muddinfun[QUOTED] likes this.
  6. Apr 30, 2018 at 2:24 PM
    Heliguy
    Heliguy Member
    Sean
    LOLOLOLOLOL! Just got off the phone with dealer service. The entire sensor unit DOES require replacement as stated above. Unit is $96. Service is $199. I will be ordering the ken-tool kit and trying that first.
