Broken 10mm bolt - Tailgate
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Quad, Nov 6, 2021.
  1. Nov 6, 2021 at 3:32 PM
    Quad
    Quad [OP] Member
    Craig
    2021 Tacoma SR5 - Cement
    Center console organizer Center console tray Bed mat
    I was putting on a tonneau cover on my truck today and the 10mm bolt near the tailgate broke. Has this happened to anyone, or does anyone have any recommendations on getting the bolt out? Also, should I buy a bolt from the dealer, or go buy a bolt from Lowe’s? Thanks!
  2. Nov 6, 2021 at 3:45 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Happened to quite a few people. Over torquing is usually the cause.
    Quad[OP] likes this.
  3. Nov 6, 2021 at 4:02 PM
    Tacospike
    Two Trucks
    Weld something to the broken bolt and twist out / drill it out without damaging nut threads
    probably Home Depot would be fine
  4. Nov 6, 2021 at 4:20 PM
    kauaihunter
    kauaihunter Well-Known Member
    Jay
    2021 SR Dbl Cab 4x4 and 2017 SR5 Dbl Cab 2wd
    Kicker speaker upgrade Tint Trimmed air dam Taco Tunes amp and sub 275/70/17 Wildpeaks
  5. Nov 6, 2021 at 4:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Left Hand Drillbits!
  6. Nov 6, 2021 at 5:09 PM
    DMel
    DMel Well-Known Member
    2020 TRD OR Cement
    Quad[OP] and Tacospike like this.
  7. Nov 6, 2021 at 5:15 PM
    steel wheels
    steel wheels Well-Known Member
    2020-ACLB-4x4-Sport-M/T
    as @eurowner said,"left hand drill bits". They work well.
    Be sure to turn them in the right direction so they cut...
    ernscott and Tacospike like this.
