Broken 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2008 tacoman, Aug 2, 2023.
  1. Aug 2, 2023 at 12:54 PM
    2008 tacoman
    2008 tacoman [OP] New Member
    2008 v6 access cab Tacoma 4x4
    A while back my Tacoma(2008 access cab v6 4x4) the drive shaft broke while I was on the highway. I got it onto a trailer by putting it in four low and driving it on the trailer. I got home and waited for my new driveshaft to get here, I put it in and now I can’t move forward or backwards in 4wd or in 2wd. It’s a manual and it stalls if I try to go forward or backwards. I need some help, any ideas help!
  2. Aug 2, 2023 at 12:55 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Is your parking brake seized?
  3. Aug 2, 2023 at 1:02 PM
    2008 tacoman
    How could I check that? My e brake sounds like it disengages.
  4. Aug 2, 2023 at 1:12 PM
    Hunter gatherer
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Jack the back wheels off the ground,disconnect drive shaft then try to turn tires by hand. If they don't move it's the brakes or the rear end. If drums are frozen sometimes you can hit them with a big hammer to break them loose. If the wheels move could be the transfer case or trans.
  5. Aug 2, 2023 at 6:24 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    If it drove in 4L with no rear drive shaft, that means the transmission spins the transfer case and the transfer case spins the drive shafts.. It also means that if the truck drove in 4L with no rear driveshaft, that the rear drums aren't seized.
    I'd leave the rear shaft on, put the transmission in Neutral, jack rear wheels off the ground and see if the drive shaft spins or you could spin the wheels. If you can't get the driveshaft or wheels to spin and it isn't the parking brake, could be the rear differential. You could go through the process to drain the rear differential oil and see if you any metal chunks in the oil.
  6. Aug 2, 2023 at 6:33 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I’m thinking rear diff. Driveshafts don’t just break. Something like rear diff locking up would put a jolt on the driveshaft and could break it. Ordinarily I’d doubt the rear diff since it rolled onto the trailer but the torque of 4LO probably helped with that.
    I’d investigate the rear diff.
    Steelhead Bum and JAGCanada like this.
  7. Aug 2, 2023 at 9:02 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Just for reference I was able to get my 1st gen tundra on a car hauler in 4hi with the rear axel completely seized. Exploded my rear diff off-road would be an understatement. Did not break a unjoint or throw the drive line however. Did crack the pumpkin in half and completely lost every tooth off of the ring and pinion gear though.
    SR-71A and BLtheP[QUOTED] like this.
  8. Aug 2, 2023 at 9:09 PM
    BLtheP
    Plano, TX
    Yeah, i mean they can break in a million different ways. I just mostly meant that he’s now having trouble driving, and it seems to reason that the rear diff could be the reason for that (as in locked up), but then it kinda defies the logic of still being able to freewheel it under its own power onto a trailer. Who knows honestly, but I have a feeling it’s the diff.
    Steelhead Bum[QUOTED] likes this.
  9. Aug 2, 2023 at 9:18 PM
    Steelhead Bum
    Mitchell
    Eastern WA
    I agree with ya. Just pointing out that I was able to limp onto the trailer under its own power with the rear diff seized. So I think you are onto something.
    BLtheP[QUOTED] likes this.
  10. Aug 2, 2023 at 9:50 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    what would happen if the new shaft was just a bit to long, could it be acting as a wedge against the TC?
  11. Aug 3, 2023 at 3:54 AM
    JAGCanada
    Canada
    I doubt it. If the drive shaft bolted up, the tcase should be able to spin it. There isn't anything in the tcase to compress. Also there is the slip joint in the rear shaft so the length of the shaft isn't constant.
    ToyoTaco25 likes this.
  12. Sep 9, 2023 at 5:17 PM
    otherphone
    otherphone Well-Known Member
    MA
    09 tacoma sport
    OME2.5lift w/medium leafs
    Just curious, did you get a complete oem driveshaft from a dealership or what?
  13. Sep 9, 2023 at 5:26 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I assume it doesn’t move (roll) in Neutral or with the clutch pressed in?
    otherphone likes this.
