Broken a/c how to still use defrost
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kflur03, Oct 26, 2018.
  1. Oct 26, 2018 at 1:16 PM
    kflur03
    kflur03 [OP] New Member
    Ac went out in middle of summer
    And never got it fix. Well. Ow it’s about to be winter and need my defrost to work. How do I get my heat to work in car without engaging the a/c? Every time I turn on the fan it makes a screeching noise because the a/c compressor is seized. The heat works fine but just no way to get it to blow
  2. Oct 26, 2018 at 1:27 PM
    Muddinfun
    Muddinfun Well-Known Member
  3. Oct 26, 2018 at 1:36 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Remove clutch plug or pull fuse like above.
    kflur03[OP] and 12TRDTacoma like this.
  4. Oct 27, 2018 at 8:03 AM
    topoutman
    topoutman Well-Known Member
    Ellensburg, WA
    2013 DCLB 4X4 TRD SPORT
    Are you sure your compressor is seized? I had something similar happen this summer and it ended up being a bad clutch on the ac unit. The rubber part that holds the clutch plate goes bad and will make a horrific howling/ squeal sound when the ac unit tries to engage.
    If this sounds like something that is going on with your truck it’s a super easy fix, removing one bolt and putting a new clutch assembly on. Lots of threads on it here. Good luck OP.
  5. Oct 30, 2018 at 1:17 PM
    gptoy
    gptoy 09 DCLB TRD Sport
    Grande Prairie, Alberta, Canada
    22 T4R TRDOR
    For those of us who aren't overly confident in the electrical world (ie: me), any chance anyone have a pic where this relay may be?
  6. Oct 30, 2018 at 1:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    there is a simple mod inside of the truck that allows you to turn on defrost without activating the AC.
    that stated.... defroster works via pulling moisture out of the air via the AC, probably wont work well just by blowing air.
  7. Oct 30, 2018 at 1:27 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    Before cars has ac, they had defrost, took for ever to get the coolant hot on cold days though. Now a days adding the ac helps it defrost faster.
  8. Oct 30, 2018 at 1:30 PM
    gptoy
    22 T4R TRDOR
    Agreed, the system may not be as effective as it's supposed to, but until I can budget $2800 to repair my system it'll have to do. Just trying to avoid waking up the neighbors with the squeal first thing in the morning is what I'd like to do for now.
  9. Oct 30, 2018 at 2:11 PM
    nd4spdbh
    SoCal
    Gotcha. Yeah check out the defrost mod. On my 2012 it was cutting one wire and connecting it to another under the dash by the blower. 10 min worth of work and it allows me full control over when the AC turns on or not, regardless of the direction of airflow.
  10. Oct 30, 2018 at 2:20 PM
    gptoy
    22 T4R TRDOR
    Ok, I'll take a look, thanks.
