Broken Antenna Assembly
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rellik01, Sep 10, 2011.
  1. Sep 10, 2011 at 9:24 AM
    Rellik01
    Rellik01 [OP] Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Broke the entire antenna assembly. How difficult to change? Does the fender need to come off? Could I replace with a power antenna (Manufacturer Recommendations).
    Thanks in advance.
  2. Sep 10, 2011 at 1:34 PM
    Rellik01
    Craig
    Windermere, Florida
    Attention MODS
    If you think this belongs in the audio section please move and I apoligize for the inconvenience.
    Thanks in advance!
  3. Sep 10, 2011 at 2:06 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    if you broke the mast itself and the base looks ok i just use a left hand drill bit on slow and when it catches it spins the piece out. i know you said entire but just checking.
  4. Sep 10, 2011 at 2:20 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    There is a special tool to remove the locknut from the top of the antenna, then the whole thing can be pulled through the fender.
  5. Sep 11, 2011 at 12:59 AM
    Rellik01
    Craig
    Windermere, Florida
    Where would I get that special tool? Does the fender need to be removed?
    Thanks
  6. Sep 11, 2011 at 10:52 AM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    Nope fender does not need to be removed. Inner fender liner yes. It snakes through the "A" post area. As far as the special tool try a jobber first and see if they have a listing. If you want to be real cool you can make your own. Some assemblies come with a new lock nut.
  7. Sep 11, 2011 at 2:39 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Snap on, mac, matco will have one. You can order online.
  8. Oct 8, 2011 at 11:17 AM
    Rellik01
    Craig
    Windermere, Florida
    Just as a follow up. I had the entire assembly replaced with a power antenna and as luck would have it the stock radio (non jbl) does have a trigger for it so it only comes up when am/fm are selected. Bought a Metra universal fit antenna for abought $50 bucks and my guy at Best Buy installed for $49.00. All in all a great upgrade as compared to paying stealership to replace with stock unit. Also my installer re used the factory trim so it looks as stock as could be. Will try to post photos at later time.
  9. Oct 8, 2011 at 12:53 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    That will be a great sticky. Give the wiring info too if you can.
    Congrats
  10. Oct 8, 2011 at 1:03 PM
    Rellik01
    Craig
    Windermere, Florida
    Unfortunetly I did not do the install. The installer did mention it was 1 of 2 pins and he just put the voltmeter on them and figured it out. He ran the wiring alongside the antenna wire, he accessed the antenna assembly from inside the wheel well after he removed the liner.
