Broken Antenna screw stuck
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bp'sTacoo824, Jul 8, 2020.
  1. Jul 15, 2020 at 10:10 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    Not sure what the other end of the power antenna harness has. I assume there is a relay to power the motor. And the associated harnesses might not connect to what you currently have. If it works out let us know!
  2. Jul 15, 2020 at 10:15 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Both my 99’s have a connector in the engine compartment that, in theory, will power the antenna
  3. Jul 15, 2020 at 10:25 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    People often times take them off to go through car washes. Water collects in the hole and they put the antenna right back on. Eventually rust forms.
    Put some antiseize on the antenna threads to help prevent this
    Seagull233 likes this.
  4. Jul 16, 2020 at 1:36 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I am sure you can adapt a aftermarket antenna to work just fine.
    In your part of the world a used one that works might be found around me not so much
    The truck should have a antenna relay someplace above and behind the radio never having looked not sure just where.
  5. Jul 16, 2020 at 12:08 PM
    MikeWH
    Colfax, CA
    1999 TRD 4x4 (x2)
    I think I can rob one from a four runner. Even out here the Tacoma’s get picked through very fast, but there are a ton of four runners. Besides it doesn’t seem like that many Tacoma’s had a power antenna option to me.
    Wyoming09[QUOTED] likes this.
