Broken Antenna. What are my options? (pic)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808Raider, Jan 4, 2012.
  1. Jan 4, 2012 at 2:01 AM
    808Raider
    808Raider [OP] Well-Known Member
    hawai'i
    Car wash snapped off my antenna and goodbye radio. base is still stuck in there it looks like how do i get it out? and I would like to get a new antenna cheap somehow what are my options? heres a pic
  2. Jan 4, 2012 at 2:06 AM
    JohnnYp
    JohnnYp Member
    Arizona
    98 SR5
    throttle body spacer k&N cold air intake stage 2 clutch kit Gibson cat back exhaust kit bed liner and rocker panel lined
    AHHHHGGG i had that happen to i ended up taking a small drill bit and started drilling slowly but before i started cutting i noticed the stud turning a lil so i got a pick and spun it out with no prob maybe itll work for you ?
  3. Jan 4, 2012 at 3:16 AM
    brians05taco
    brians05taco Well-Known Member
    Brian
    Lafayette,La.
    05 prerunner white debadged 4.0
    lifted, bedcover,BHLM, grill, etc...
    left handed drill bit and a easy out
  4. Jan 4, 2012 at 3:38 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Yeah that broken stud should be pretty loose in there, so it should be pretty easy to work out. The left handed drill bit sounds like a good choice. But you might just want to see if you can get a small flat head on it, and with a little pressure, unscrew it out. If it's not a completely smooth break and there's any friction to be had, the flathead might be enough to catch it & rotate it out.
    For antenna options, check out www.antennax.com. I run the 13" "Eurostyle" flexible antenna. I don't listen to a lot of radio, but when I do, reception is no problem. Just make sure you unscrew your next antenna before the automatic car wash! They tear them up. ;)
  5. Jan 4, 2012 at 4:19 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Small drill bit and a easy out.
  6. Jan 4, 2012 at 7:09 AM
    StickShifty
    StickShifty Well-Known Member
    New Jersey
    2012 AC 4WD 6SPD
    like others have said.
    these are easy outs, they work wonders and are very easy to use.
    you can always get a aftermarket shorter antenna.
  7. Jan 4, 2012 at 7:15 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I have used these before to remove the broken piece for a customer. I use them anytime a bolt or screw gets broken like that.
  8. Jan 4, 2012 at 7:24 AM
    Aw9d
    Aw9d That one guy
    if you don't have the bit, use a dot of JB weld and weld it back together, let it dry, then take it out. Just don't let the weld leak out or your boned. Use just a small dot, should be strong enough to back it out.
    The left handed bits will be a better solution to your issue, but if you don't want to buy them JB weld may work for ya.
  9. Jan 4, 2012 at 7:27 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Be very careful if you go this route. As he said, if the JB Weld runs and gets into the threads you will not be able to get it out.
  10. Jan 4, 2012 at 8:07 AM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    that ..
  11. Jan 4, 2012 at 5:50 PM
    AntennaX
    AntennaX Well-Known Member
    yes, try to drill it out, and then get one of our antennas. be sure to unscrew before going thru car wash!!
  12. Dec 25, 2012 at 2:14 PM
    tacohound
    tacohound Well-Known Member
    Andy
    Cape Cod
    2011 DCSB TRD Sport
    Smitty built light bar, 4 Hella 550's, Tan HLM and badges, Black sport rims
    I used the flathead screwdriver portion of my Gerber to work it out.
  13. Dec 25, 2012 at 2:19 PM
    KFD208
    KFD208 Active Member
    Delaware
    2016 Tacoma TRD Sport
    I agree with these....they work very well on broken and stripped out screws.
  14. Dec 15, 2015 at 3:39 PM
    Lifeofbrian
    Lifeofbrian Longing for the far East
    Brian
    Westminster, CO
    2010 TUNDRA 5.7 Rock Warrior
    Stuff
    Broke mine off this morning cleaning snow off, lol... You guys rock. Thanks for the tips on this subject.
