Broken Antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WilsonTheDog, Dec 28, 2009.
  1. Dec 28, 2009 at 6:57 PM
    WilsonTheDog
    WilsonTheDog [OP] Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Went to car wash, asked "Is my antenna OK or will it break?". Answer: "As long as it's tight, it's fine.". We know what happened next = antenna broken. The threads were broken off in the base, I tried 10 different ways to get it out, finally drilled, and now it's all fuxored. I was able to use a tap and put some threads in for a new antenna (OEM style replacement) which is in there now but reception sucks and it isn't too pretty up close since I had to tap it off center.
    This is why I never go to car washes but I was up in NJ during and after the snow storm and had to get the salt off. FML.
    So the question is, how do i get the base off to replace it? What parts do I need?
    Thanks in advance.
  2. Dec 28, 2009 at 7:06 PM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Did you try sawing the tip off an allen wrench then supergluing the handle end to the stub and then backing it off with a drill REAL slow? Will also work with any suitable, hex-shaped shank.
  3. Dec 28, 2009 at 7:10 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    That thing was in there too tight for that, unfortunately. I cut a slot in to use a screwdriver and even that wouldn't work. I'm beyond that point now anyway as it's already been drilled.
  4. Dec 28, 2009 at 7:22 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Just found my FSM on my computer. Researching...
