Broken crankshaft key leads to tear down and timing service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p16, Feb 12, 2024.
  1. Feb 25, 2024 at 6:15 PM
    #181
    p16
    p16 [OP] Well-Known Member
    2005 Tacoma V6 4.0 L 4x4
    Also I ended up going with the national seal for the record…
  2. Feb 25, 2024 at 6:24 PM
    #182
    zguy1
    zguy1 Well-Known Member
    Midwest
    You're a rebel... Look at me, I am Toyota parts snob who replaced his own head gaskets and used all Toyota parts except for the head bolts. I'm in no position to judge.
    All seriously now, we are 10 pages in on this thread, let's get this repair going so we can see some progress on this thing...
    p16[QUOTED][OP] likes this.
  3. Feb 25, 2024 at 6:26 PM
    #183
    p16
    Still waiting for the water pump and harmonic balancer in the mail. I’ve got everything stripped down ready to take off valve covers and timing cover but just want to wait till I have the parts so my engine isn’t open and exposed to the elements(it’s parked outside in my dirt driveway because I don’t have a garage). Believe me, y’all will get a full update when the repair is complete this week hopefully
    Jimmyh and zguy1[QUOTED] like this.
  4. Feb 25, 2024 at 6:28 PM
    #184
    p16
    Here is a pic to tide you over. I put the covers back on with two bolts each just to keep it all clean.
    Torspd and Jimmyh like this.
  5. Feb 25, 2024 at 6:31 PM
    #185
    TacoTuesday1
    SD CA
    hood closed should keep rain out.
    If you want might be possible to drape a cover over anything open
    to speed up the job allowing to get started on any cleaning and prep involved in components that might get re used
    such as covers. Like cleaning, degreaser, scraping, etc.
    Wish I painted my valve covers back when I released them rather than just fast gasket renew job.
    drawback is having to remember what goes where and laying things out in an organized matter or labeling, pics, etc
  6. Feb 26, 2024 at 10:51 AM
    #186
    p16
    Ok well here is where I’m at. I got the timing cover off and when setting to Tdc I noticed that I am missing a mark down near the crankshaft gear. The mark on the block is lined up with the gear mark that corresponds with the key, however the gear mark that is supposed to line up with the crank sprocket mark seems to be non existent. After rotating multiple times I can’t find more than one mark so I’m beginning to think it wore off somehow? I should be at Tdc tho. Chain seems to have some slack so the marks on the cam sprockets are a little off but they are at the approximate position they should be at when at Tdc. My lobes seem to show Tdc as well.
    Torspd likes this.
  7. Feb 26, 2024 at 10:53 AM
    #187
    p16
    If I’m correct there should be another mark right here
  8. Feb 26, 2024 at 10:57 AM
    #188
    Clearwater Bill
    Billy
    Largo Florida
    18 yrs of age
  9. Feb 26, 2024 at 11:01 AM
    #189
    Clearwater Bill
    Billy
    Largo Florida
    This type problem was common on early Miatas, called 'short nose crank' in that case.
    Google short nose crank Miata lance schall and see if that on vehicle repair procedure will work for you.
    It's based on very specific Locktite products
    Or poke around on Miata.net
    No, it's not the same root cause situation, but I'm thinking the repair could work
    GilbertOz likes this.
  10. Feb 26, 2024 at 11:22 AM
    #190
    zguy1
    Midwest
    No, there is no mark there. There is only the mark on the cylinder block that aligns with the key on the crank. That is TDC. You will use the dot on sprocket to install the chain after removing it. That dot will appear to be approximately in the 9 o'clock position.
    From your pictures, it looks like you are at TDC. Your main chain does not line up but it will if you continue to turn over the motor. You do not need to do this, but if you are looking to prove it to yourself you could continue to do so.
  11. Feb 26, 2024 at 11:27 AM
    #191
    p16
    What about this mark here(picture pulled off YouTube). I don’t see it on mine. But I agree either way I believe I’m at Tdc right now
  12. Feb 26, 2024 at 11:30 AM
    #192
    zguy1
    Midwest
    Here was mine.
    p16[OP] likes this.
  13. Feb 26, 2024 at 11:30 AM
    #193
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Here's a kind of odd/cheesy video, but good for a reference. Your first pic shows the crank in the right position, and the other sprockets appear to be lined up.
    p16[OP] likes this.
  14. Feb 26, 2024 at 11:31 AM
    #194
    p16
    That makes me feel better. Weird that there are marks there for some but not all. Could just be worn down I guess?
  15. Feb 26, 2024 at 11:32 AM
    #195
    zguy1
    Midwest
    My FSM does not talk about another mark there. I'm not sure what you are referring to.
  16. Feb 26, 2024 at 11:36 AM
    #196
    p16
    Yes I don’t believe I ever saw it in the fsm. I guess I’ve just seen it on the videos I’ve been watching such as in the picture I uploaded above. As long as I have the key and that one mark lined up to the timing mark on the block I should be good and ready to take everything off though
    Jimmyh likes this.
  17. Feb 26, 2024 at 11:42 AM
    #197
    zguy1
    Midwest
    You can move forward with confidence. Things may move a bit with the chain off. You can always fall back to the position of the gears relative to the bearing caps. The camshaft lobes are helpful as you mentioned. Remember some of the valves are open so you will need a crescent wrench (on the flats of the cams) to reinstall the main chain since the valve springs will want to close the currently open valves.
    p16[OP] likes this.
  18. Feb 26, 2024 at 11:45 AM
    #198
    p16
    Once the main chain is off I have to adjust the cam shafts with the crescent wrench correct? So the marks line up to the bearing caps?
  19. Feb 26, 2024 at 11:57 AM
    #199
    zguy1
    Midwest
    In a perfect world, let's assume you have everything at TDC currently and the crankshaft bolt is loose. Meaning, you can loosen it by hand without affecting the position of the crank. Once you remove the chain, following the FSM, the crank and bank 1 should remain in their current position. Notice the lobes on the intake cam on bank 2, you can see that the valves are slightly open currently. Once you remove the main chain, the bank 2 cams will move. During installation, you will need to slightly turn the cams on bank 2 in order to align the marks on the caps and gears like they currently are. You will use your large crescent wrench on one of the cams in bank 2 in order to do so.
    Hopefully that makes sense.
    p16[OP] likes this.
  20. Feb 26, 2024 at 12:45 PM
    #200
    p16
    I believe it does
