Broken crankshaft key leads to tear down and timing service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p16, Feb 12, 2024.
  1. Feb 28, 2024 at 2:06 PM
    #221
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Torspd and p16[QUOTED][OP] like this.
  2. Feb 29, 2024 at 3:08 PM
    #222
    p16
    p16 [OP] Well-Known Member
    2005 Tacoma V6 4.0 L 4x4
    So I’m trying to set the timing and I’m having quite the issue. I get my cam sprockets all lined up but when I install the idler pulley it puts too much tension on the driver side cams and pulls them out of timing… any recommendations?
  3. Feb 29, 2024 at 3:12 PM
    #223
    zguy1
    zguy1 Well-Known Member
    Midwest
    Did you take tension off the tensioners before installation? Meaning, I made sure all was aligned and everything was installed before I released tension back on the chain.
  4. Feb 29, 2024 at 3:13 PM
    #224
    p16
    There is tension on the small cam chains but not the main. Should I take the tension off of those too when installing the main one?
  5. Feb 29, 2024 at 3:20 PM
    #225
    zguy1
    Midwest
    Hmmm. I don't recall having an issue. I just remember making sure that the idler pulley was centered on the main chain before installing the bolt that holds it.
  6. Feb 29, 2024 at 3:25 PM
    #226
    p16
    I can’t get it right for the life of me. I set the timing on the cams but every time I screw in the idler it just sets it off barely
  7. Feb 29, 2024 at 3:27 PM
    #227
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Sounds like you need to start with it off a little so that when you release it, it pulls it into alignment.
    b_r_o likes this.
  8. Feb 29, 2024 at 3:27 PM
    #228
    p16
    Already tried that a bunch of times it still pulls it too much
  9. Feb 29, 2024 at 3:34 PM
    #229
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    This guy does the idler and cam sprockets first, then does the crankshaft. He does it with the guides/tensioners off to give enough chain slack.
  10. Feb 29, 2024 at 3:52 PM
    #230
    p16
    Yeah I’ve been watching that video. I don’t have a goddamn gear puller so I can’t get my crank sprocket off right now unfortunately
  11. Feb 29, 2024 at 4:01 PM
    #231
    zguy1
    Midwest
    Are you following the steps in the FSM for installing the chain? Btw, I didn't replace or remove the camshaft sprocket. I only removed the idler gear when I did my head gaskets.
  12. Feb 29, 2024 at 4:07 PM
    #232
    p16
    Yes I am getting this issue when I follow the steps
  13. Feb 29, 2024 at 4:08 PM
    #233
    p16
    I’m on my way to the auto parts store to pick up a gear puller. Hopefully that helps
  14. Feb 29, 2024 at 4:22 PM
    #234
    zguy1
    Midwest
    You don't need to remove the sprocket to install the chain.
  15. Feb 29, 2024 at 4:38 PM
    #235
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    why does that man have no nipples? and whats up with his rotting zombie flesh around the rib cage?
  16. Feb 29, 2024 at 5:01 PM
    #236
    p16
    I know I prefer not to but doing it this way obviously isn’t working for me.
  17. Feb 29, 2024 at 5:19 PM
    #237
    zguy1
    Midwest
    Maybe I missed something earlier, were you able to replace the key(s) on the crankshaft? I thought that was the main reason why you removed the cover.
  18. Feb 29, 2024 at 5:23 PM
    #238
    p16
    Yes I was able to remove the key. I am also doing new timing component while I’m in here. The issue I’m having is whenever I tighten the idler sprocket and it sets into place it pulls on one side of the cams and sets them slightly off.
  19. Feb 29, 2024 at 5:27 PM
    #239
    p16
    Ever so slightly
  20. Feb 29, 2024 at 5:31 PM
    #240
    p16
    Razor blade as a straight edge for reference
