Broken crankshaft key leads to tear down and timing service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p16, Feb 12, 2024.
  1. Mar 2, 2024 at 11:05 AM
    #281
    zguy1
    zguy1 Well-Known Member
    Midwest
    Thanks for sharing. I was curious about the actual repair. Does the sprocket need to be pulled or does it just slide off the crank? Once the sprocket is off, does the key simply slide out?
    p16[OP] likes this.
  2. Mar 2, 2024 at 11:08 AM
    #282
    p16
    p16 [OP] Well-Known Member
    2005 Tacoma V6 4.0 L 4x4
    The key was a little mangled so I tapped it out first with a hammer and flat head screwdriver and then used a needle nose vice grip to wiggle it out. After that I had to use a puller to get the sprocket off but that was pretty easy once I rented the 3 jaw puller. I was worried it would be a bitch to get out but with the timing cover off it was pretty smooth sailing
    Jimmyh and zguy1[QUOTED] like this.
  3. Mar 2, 2024 at 11:23 AM
    #283
    p16
    Anyone have a pic of their timing cover with the silicone gasket on it before they installed? I’ve read the fsm and seen what it says to do but I’m just wondering if there’s such thing as too much gasket on there. I think the manual says 3-4mm worth
  4. Mar 2, 2024 at 11:25 AM
    #284
    TacoTuesday1
    FL
    asking the internet for torque specs instead of reading the FSM which is free is how one blows a motor.
    whatever the spec is. It’s always different.
    Based on the spec you can cut the tube nozzle to the right width for laying sealant and do a practice dry run with measuring gauge to verify it is laying down that amount.
    p16[QUOTED][OP] and zguy1 like this.
  5. Mar 2, 2024 at 11:28 AM
    #285
    p16
    Reason I asked is because I couldn’t find it on the manual myself
  6. Mar 2, 2024 at 11:28 AM
    #286
    zguy1
    Midwest
    Check my link I provided earlier in the thread. I would suggest viewing that before starting. A lot of your questions will most likely be answered there.
    p16[OP] likes this.
  7. Mar 2, 2024 at 11:35 AM
    #287
    zguy1
    Midwest
    Remember test fit, test fit and test fit the cover before applying any FIPG. Know how the key from the oil pump goes over the crankshaft.
    Also make sure about the gasket that goes between the cover and oil pan. I used grease to hold it in place but there maybe other suggestions. Don’t mess that step up.
    Steves104x4 and p16[OP] like this.
  8. Mar 2, 2024 at 11:49 AM
    #288
    p16
    Are you referring to the o ring from the oil pump or the gasket maker on the cover and pan surfaces?
  9. Mar 2, 2024 at 11:54 AM
    #289
    zguy1
    Midwest
    Regarding the gasket with grease? I’m referring to the one that goes on the bottom of the cover which is visible on the oil pan cover which is exposed below the crank.
  10. Mar 2, 2024 at 12:03 PM
    #290
    p16
    This right?
  11. Mar 2, 2024 at 12:04 PM
    #291
    zguy1
    Midwest
    Yes, the underside of that. There was a gasket there. If you don’t use something like grease the gasket will not stay in place during installation.
    Torspd and p16[OP] like this.
  12. Mar 2, 2024 at 12:20 PM
    #292
    p16
    Ohh understood
  13. Mar 2, 2024 at 12:23 PM
    #293
    p16
    How does grease help it stay in place?
  14. Mar 2, 2024 at 12:28 PM
    #294
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Such a little thing. Such a big hassle.
    p16[OP] likes this.
  15. Mar 2, 2024 at 12:30 PM
    #295
    zguy1
    Midwest
    Go ahead and try it a few times without it. If you are not using any grease, then it will not stay on the cover once lifted upright. If you put it on the pan then there is a chance that it will push in as opposed to maybe coming out where you can see it during installation. Remember you need to make sure that any surface where the sealer (FIPG) is installed must be oil free. Since the surfaces are clean there is a chance that gasket will grab the pan and slide off.
    p16[OP] and Torspd like this.
  16. Mar 2, 2024 at 12:31 PM
    #296
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Put a few dabs of silicone into the recess for the oil pump o-ring. Or even a small bead. That will hold the gasket, as you slide it over the mating surface of the oil pan.
    When installing the timing cover with the pan in place, I always smear the silicone on the oil pan, versus a standing bead. Works better at preventing future leaks.
    b_r_o, p16[QUOTED][OP] and zguy1 like this.
  17. Mar 2, 2024 at 12:33 PM
    #297
    zguy1
    Midwest
    You have options. This forum is a gold mine.
  18. Mar 2, 2024 at 12:40 PM
    #298
    545
    545 Well-Known Member
    2015 Access Cab
    woodruff keys by design are ”weak”, or basically strong enough. They aren’t hardened steel like the crank
    that’s the sacrificial part. Generally they shear along the rotation if there is an issue, never seen someone crush one before. Lol
    Torspd likes this.
  19. Mar 2, 2024 at 12:40 PM
    #299
    p16
    And you guys are the miners
  20. Mar 2, 2024 at 12:43 PM
    #300
    p16
    I’m just that good i know. It is nice thought being able to switch out a key and not having to replace the entire crankshaft
    Jimmyh likes this.
