Broken crankshaft key leads to tear down and timing service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by p16, Feb 12, 2024.
  1. Feb 15, 2024 at 8:08 PM
    #81
    p16
    p16 [OP] Well-Known Member
    2005 Tacoma V6 4.0 L 4x4
    Also before taking the timing off I have to find TDC right? Do the colored chains have to line up with the marks at Tdc before you can disassemble or only the ones on the sprockets?
  2. Feb 15, 2024 at 8:42 PM
    #82
    Anteupp
    Anteupp Mega Member
    align the crank key with the timing mark on the block , then check if the marks on the cylinder head sprocket assembly match the mark's on the bearing caps behind it.
    p16[OP] likes this.
  3. Feb 16, 2024 at 1:18 AM
    #83
    TacoTuesday1
    FL
    Typically on a chain you're rotating the crank clockwise from the front until the timing marks are lined up,
    and can have the plugs out both to not be fighting compression, and stick something long inside that goes up and down with the piston showing it's at TDC as well.
    Read the FSM.
    p16[QUOTED][OP] likes this.
  4. Feb 16, 2024 at 3:31 AM
    #84
    p16
    How do you know it’s at compression and not exhaust? The old chains colored chains don’t have to be lined up with the marks as well right? This is all it said on the manual I found.
  5. Feb 16, 2024 at 3:54 AM
    #85
    TacoTuesday1
    FL
    1: generally, if everything is lined up, then it is right. Certain pistons will be at the bottom. Certain ones will be at the top.
    2: don't know what "cardiagn" is. Never heard of it. Deep engine repair you should probably do the following
    -have and consult the FSM
    -access the FSM online for free
    -purchase day pass to FSM; no point in doing that considering the above options
    you can read all the other stuff and youtube videos you want
    but consider if a tech was doing something, they wouldn't be doing that instead, in addition to that being inefficient on time. They'd be reading the FSM.
  6. Feb 16, 2024 at 7:05 AM
    #86
    Anteupp
    Anteupp Mega Member
    all the valves will be closed lol
  7. Feb 16, 2024 at 10:30 AM
    #87
    zguy1
    zguy1 Well-Known Member
    Midwest
    If you follow the FSM, as noted above, you can set TDC of cylinder #1 by the marks on crankshaft and the cylinder block. At this point cylinder #1 is TDC but you do not know whether it is getting ready to start its intake or power stroke. After you remove the timing cover, take note of the marks on the camshafts in relationship to the bearing caps. If they do not line up as indicated, rotate the crankshaft another 360 degrees to align the marks as indicated. At this point the timing is set. The colors on the chain may or may not line up with all the marks. During installation of the timing chain, you will use the marks on the crankshaft and block, camshafts and bearing caps and the colors on the chain. If you do not use the colors on the chain as well, you risk setting the timing incorrectly.
    By the way, when cylinder #1 is TDC, there will be some cylinders with valves open, partially or closed.
    Hope that helps clarify.
    p16[OP] likes this.
  8. Feb 16, 2024 at 10:42 AM
    #88
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pull the spark plugs. Make rotating the engine easy on yourself.
    Jimmyh and p16[OP] like this.
  9. Feb 16, 2024 at 3:28 PM
    #89
    TacoTuesday1
    FL
    if you end up making marks to make things more visible
    get paint
    Dollar store whiteout
    or paint marker pen from a store or online
    Brakleen the area first so it sticks on the metal. Maybe wire brush and wipe with rag first.
    Better than a regular black permanent marker.
    p16[OP] likes this.
  10. Feb 16, 2024 at 4:39 PM
    #90
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would use an industrial paint marker pen.
    p16[OP] likes this.
  11. Feb 16, 2024 at 9:06 PM
    #91
    p16
    I assume that I should drain oil and coolant?
  12. Feb 16, 2024 at 9:21 PM
    #92
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yes. If you are doing the chain, you should do the water pump as well.
  13. Feb 16, 2024 at 9:37 PM
    #93
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There are two coolant passages in the timing cover, that go into either side of the block. So yes, you'll need to drain the coolant. There is a small drain valve on either side of the block as well, to drain out the coolant passages around the cylinders.
    Jimmyh and p16[QUOTED][OP] like this.
  14. Feb 16, 2024 at 10:37 PM
    #94
    p16
    Thank you. Also is the yotashop timing kit confirmed oem Toyota parts?
  15. Feb 17, 2024 at 6:55 AM
    #95
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    They are a well-respected vendor in the Toyota community, I wouldn't worry about counterfeits from them. You might use eBay if the seller is a Toyota dealer that you can verify, but most local dealers will price match if you ask. I wouldn't use Amazon.
    #95
  16. Feb 17, 2024 at 7:32 AM
    #96
    p16
    I asked the eBay seller and he said they’re a distributor not a dealer. Part of me wants to go for it cause of the affordability. The seller has many positive verified purchase reviews, one even saying they bought a timing kit from them and it’s still going strong after 160k miles.
    #96
  17. Feb 17, 2024 at 7:54 AM
    #97
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
    Eh, those can be faked. What is the cost compared to the Yotashop kit? Are they saying it's genuine OEM? If there's a significant price difference, it's likely a fake.
    For me, a better alternative would be the INA kit that RockAuto sells. Quite a bit cheaper than OEM but from a legit company and seller.
    #97
  18. Feb 17, 2024 at 7:55 AM
    #98
    p16
    It’s like $500 and yeah they claim it’s all oem. Yeah I was looking at the INA but it’s so cheap I thought it might be no good either lol. Ima call the local Toyota dealership and get a quote from them for a timing parts.
  19. Feb 17, 2024 at 8:02 AM
    #99
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    OEM pulley only. Trust me on this. I went through 3 aftermarket pulleys in a very short time
  20. Feb 17, 2024 at 8:17 AM
    #100
    545
    545 Well-Known Member
    2015 Access Cab
    I’d slap a new oem crank pulley on it like it is with retaining compound and send it before I used non oem (or suspect) timing parts
    loktite 638 has a 4500psi shear strength. A lot of surface area on the pulley and shaft, plus whatever is left of the key, plus the crank bolt. I doubt it would come lose if you clean the surfaces well and let it cure
    Can always be removed with heat, although it would likely smoke the rubber in the pulley
    bfonic and p16[QUOTED][OP] like this.
