Broken CV Snap Ring
Discussion in 'Long Travel Suspension' started by amadougrand, Oct 25, 2020.
  1. Oct 27, 2020 at 4:05 AM
    Spraynard
    Spraynard Priapism survivor
    hagrid
    Pittsburgh
    '19 AeroTundra PRO
    When you perform the next install try to get me a picture of a fresh snap ring, plz.
  2. Oct 29, 2020 at 8:42 PM
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    Did you work the snap ring in on the start? Or did you just hammer it in? If you set it in and press it in while pushing down on the shaft it will not get pinched. From looking at the ends they seem to be sheared off I would say it looks like it was forced in before it was seated... below is a pic of a factory ring with some miles on it. Also the first CV I built I just slammed the clip in and part of it got cut off and compromised the link... Anyway hope this helps
    Spraynard likes this.
  3. Oct 29, 2020 at 8:45 PM
    04TacoRunner
    CC TX
    looking @ your pic again and the fact that both ends are sharp on the same sides I would say they were cut on the splines and were not seated properly when being installed... Also that one side towards your wrist almost matches the splines shape perfectly...
  4. Oct 30, 2020 at 5:13 AM
    amadougrand
    amadougrand [OP] Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    I have to agree with both of you. I didn’t do the install, but I have discussed the thought with those who did. We are going to cycle the front and look, but can’t see anyway that a bind occurred that would have put that much force to shear the ring.
  5. Nov 4, 2020 at 3:25 PM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Spoke with shop today. They have been on the phone with RCV and TC. Seems this isn’t uncommon at full droop (even limited) and full lock turn. Not sure if is willow that completely yet, but that was the current word. Supposedly the TC engineer is looking into it for this suspension setup.
    Spraynard and Dalandser like this.
  6. Nov 7, 2020 at 6:48 PM
    04TacoRunner
    CC TX
    Limit straps do stretch but in the end it's just simple geometry so something was out of alignment for this to happen. I have always set my limit straps lock to lock lifted not with wheels straight... Curious how many extended travel kit's has this shop installed? If you strap it with the wheels straight you will over extend them when lock to lock. Any way for that ring to snap there was a bit of a bind and it was either strapped or bumped improperly so this would be the first thing to check. Any way hope this helps
    tacotunner06 likes this.
  7. Nov 10, 2020 at 5:26 AM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Thank you for the guidance, agree with you, but the dimple where the snap ring broke appear could have been incorrect install also. Will ensure the limits are set on full lock this go around also.
