Broken Door Handle: two part epoxy?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beedoola, Aug 6, 2013.
  1. Aug 6, 2013 at 11:46 AM
    beedoola
    beedoola [OP] Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    I went to open my driver side door this morning when part of the half cracked/tore. Probably a quarter is still attached. How hard is it to dismantle the door to put a new handle in?
    Would two part expoxy drying over night be enough to temporarily fix it? I don't have the time at the moment to take the door apart to replace the handle...
  2. Aug 6, 2013 at 12:00 PM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    It fixed my dads Tundras tailgate handle for the longest time before he replaced it. Im sure to replace it you'll have to remove the inside door panel and it'll be on with a couple screws.
  3. Aug 6, 2013 at 3:17 PM
    cmf21
    cmf21 Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    It sucks. I had to replace both of mine earlier this year. It took me a while to figure out how to remove it and put it back without losing any parts inside the door.
  4. Aug 6, 2013 at 10:57 PM
    beedoola
    San Francisco, CA
    How much was a new handle/enclosure and where did you order it from? Thanks.
  5. Aug 7, 2013 at 2:32 AM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I found a cheap pair of genuine Toyota handles off Ebay. I think they were around $25 a side. Anyways, if you look there are a lot of aftermarket handles starting around $12 or so.
  6. Aug 7, 2013 at 5:48 AM
    roguewaave
    roguewaave Well-Known Member
    Texas/Maine
    stock
    stock
    My passenger side is broken also along with my small rear window latch, I think I'm going to replace both handles. Just have to find a good source. I'll try ebay, if not there the stealership I guess.
    I'll post up what I find.
  7. Aug 8, 2013 at 2:32 AM
    hawaiifiveo
    hawaiifiveo Well-Known Member
    Bobby
    2002 Tacoma X-cab 4x4 TRD
  8. Aug 9, 2013 at 4:45 AM
    roguewaave
    Texas/Maine
    stock
    stock
    Sold, thanks five0
  9. Aug 10, 2013 at 8:54 PM
    beedoola
    San Francisco, CA
    So the expoxy didn't hold well. I got one of the cheap handles off eBay; like $13 shipped. It arrived super fast and I installed it today. Took about 15 minutes. I ended up breaking the plastic piece that holds the u-pin for the manual window; l have to expoxy that now, lol.
    The handle is definitely "cheaper" feeling but fit right in and seems to work fine:
  10. Aug 11, 2013 at 4:01 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    Nice job! New handle is looking good
