Broken door handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by RBFinley, Jul 22, 2025.
  1. Jul 22, 2025 at 7:41 PM
    RBFinley
    RBFinley [OP] New Member
    2004 Tacoma
    So I have tried to replace diver side and passenger side exterior door handles. But once I installed them, it didn’t fix the problem. What I noticed was that the lever on the new handle that is suppose to push down the part that releases the lock, it pushes it out instead and the lock doesn’t release. Any suggestions?
  2. Jul 22, 2025 at 8:36 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    When you say "lock" do you mean the latching mechanism? The door handles don't affect the locks at all.
  3. Jul 22, 2025 at 11:03 PM
    Glamisman
    Glamisman Well-Known Member
    I have always taken the latch assembly out completely, cleaned it, greased it, tested it and reinstalled it. Yes kind of a pain but when I am done it is a 1 finger lift to open the door.
  4. Jul 23, 2025 at 4:37 AM
    RBFinley
    2004 Tacoma
    Yes I guess I do mean the latching mechanism @glwood6. I will take a picture when I get back home of what I am talking about or video.
  5. Jul 23, 2025 at 6:16 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    Why did you replace the pull handles? Is this issue the same as before you replaced the handles?
    If the answer to my second question is yes then I suspect your problem is the latch mechanism.
  6. Jul 23, 2025 at 9:27 AM
    RBFinley
    2004 Tacoma
    The issue is not the same. The actual handle broke which is why I was replacing them.
    t0p_d0g likes this.
  7. Jul 23, 2025 at 11:29 AM
    Woodcutter
    Woodcutter Well-Known Member
    Missouri
    3.4L V6 96 Taco 4 x 4 SR5
    So all the work done was only these two exterior handles? The interior handles were not removed or adjusted to aid in the exterior door handle R&R?
  8. Jul 23, 2025 at 11:41 AM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    Over the years I've replaced a lot of broken door handles for the fleet I'm responsible for. Learned early on that the issue was almost always worn door hinges.
    Door hinges wear. Doors sag. Guys start pulling up on the door handle when they close the door to make it close right. Eventually the exterior door handle breaks.
    Not saying that's this case....but it wouldn't hurt to check.
  9. Jul 23, 2025 at 11:52 AM
    Glamisman
    If the handles are original... 20 years is a pretty good run, if they are 3 years old, there is a problem.
