Broken Down, Brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CedarPark, Nov 27, 2016.
  1. Nov 27, 2016 at 12:23 PM
    CedarPark
    CedarPark [OP] Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    hey y'all hoping for some advise
    Was slowing down from 65 all of a sudden my truck shuttered and I wasn't moving anywhere. Something from the front driver side is completely binded up, was able to force it off the road but won't move in parking lot. However, everything seems completely fine in reverse?...
    Waiting on a jack as a buddy was borrowing mine, but the caliper is still held on. Figured maybe it was something in the caliper?.. I have an Aussie but I don't know why would it would only let one side move, it's never had issues in 2WD
    Thanks
  2. Nov 27, 2016 at 12:24 PM
    CedarPark
    Dylan
    Cedar Park, TX
    It will drive with a good amount of gas but it sounds like something is grabbing and grinding the caliper.. just don't see anything
  3. Nov 27, 2016 at 12:28 PM
    PottMatter
    PottMatter Well-Known Member
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    Get the tire off and pull the bolt and swing the caliper up, bet is the backside pad is down to nothing and wedging up
  4. Nov 27, 2016 at 12:36 PM
    CedarPark
    Dylan
    Cedar Park, TX
    Pads have maybe 12k tops on em, maybe uneven wear but no sure why they would. Buddy with a jack is right down the road guess we'll take a look
  5. Nov 27, 2016 at 1:05 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Locked up caliper?
  6. Nov 27, 2016 at 1:06 PM
    CedarPark
    Dylan
    Cedar Park, TX
    Took the caliper off easy and everything seemed fine with it
  7. Nov 27, 2016 at 1:07 PM
    PottMatter
    CoLoRfUl CoLoRaDo
    2012 Red Baja Taco
    Try spinning hub...
  8. Nov 27, 2016 at 1:47 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    If the brake pads are good and not binding on the rotor, then you got a wheel bearing going bad.
    It sound like you have some trouble.
  9. Nov 27, 2016 at 2:07 PM
    CedarPark
    Dylan
    Cedar Park, TX
    It def seems like something front diff related, ring and pinion?... it's bad heh
  10. Nov 27, 2016 at 8:31 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    well with your add, one side should still spin freely if the R&P when you jack it up can you spin both wheels? or just the pass wheel?
  11. Nov 27, 2016 at 10:19 PM
    SavageTacoma91
    SavageTacoma91 Well-Known Member
    Daniel
    Meadow Vista, CA
    2008 Toyota Tacoma V6 4x4 Access Cab
    X2 on the wheel bearing
  12. Nov 27, 2016 at 10:53 PM
    icallhertaco11
    icallhertaco11 Well-Known Member
    Jamie
    Texas
    2008 Tacoma Prerunner v6
    Engage Long Travel 6 over with race spindles. 2.5x8 sway a ways wrapped in King Coils.
    I'd say bearings as well, my truck just went out on me. The driver side. Wheel wasn't locked up but was hearing loud cracking noises moving forward as I was pulling out of a parking spot. It was my bearings I don't know what they're doing but I towed it home and have new ones from bama boy coming. But when the truck is in reverse the wheel straightens up and doesn't pop at all.
  13. Nov 27, 2016 at 11:16 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Sounds like the bearing, but check your flex hose on that side. It could be junk and not releasing the pressure right away.
  14. Nov 28, 2016 at 10:20 AM
    icallhertaco11
    Jamie
    Texas
    That could cause a loud cracking? I mean it's not when I'm breaking I rolled for a good 10 to 20 seconds with consecutive cracking noises just about every half rotation of the wheel.
