Broken Exhaust Bolts - Damage Control Advice?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mjohn617, May 19, 2011.
  1. May 19, 2011 at 2:25 PM
    mjohn617
    mjohn617 [OP] Well-Known Member
    Petaluma, CA
    05 DC TRD sprt silver
    I just started my clutch replacement and came into a problem. After plenty of penetration spray and soft touch, I have broken two bolts off at the catalytic converters and one just aft of the system at the two compression fittings.
    Does anyone have some advice on what I should do? I am thinking about cutting the rest of the bolts off and drilling out the broken pieces out...or just buying long tube headers and exhaust.
    I really don't want to drop that kind of money on new shit, but I also don't want to remove the exhaust manifold to properly drill.
    THIS SUCKS!
  2. May 19, 2011 at 2:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You should be able to drill them, then use a tap & Die set to extract the remaining part of the bolt.
  3. May 19, 2011 at 2:53 PM
    mjohn617
    Petaluma, CA
    I don't think I am going to be able to, I put pictures up, it's bad!
  4. May 19, 2011 at 6:29 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Just drill out the bad ones and use a locknut and bolt instead.
  5. May 19, 2011 at 8:29 PM
    mjohn617
    Petaluma, CA
    Thanks guys, that was my first attempt, drill out and clean up with a tap.
    I spent two hours on these bolts with a grinder and drill trying to get the flange flush to start drilling. Unfortunately the shop I am working at is a military hobby shop and is a borderline shit hole.
    I brought all my tools but no grinder or drill. The shops one is shit, I cut the exhaust!
    So my next move is I guess TRD exhaust and maybe Doug Thorley LTH.
  6. May 19, 2011 at 9:16 PM
    mjohn617
    Petaluma, CA
    So I am checking out TRD catback exhaust and it looks like it does not go all the way to the cats, can anyone validate this? Do I still use the stock Y-section between the cats and the collector....the one I just cut today :)
  7. May 19, 2011 at 9:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. It goes until the Y. You can get a URD "Pipe Bomb" (IIRC) and that will take the place of the peice you just cut.
  8. May 19, 2011 at 10:33 PM
    mjohn617
    Petaluma, CA
    Thanks Chris4x4, I did some searching tonight and found that pipe from URD...looks like the only company making these.
    I have had a complete exhaust on the back burner now for a while...ordered it tonight!
    I just ordered a TRD cat-back exhaust, Doug Thorley LTH and Y-pipe, should have an interesting next week. :D
    I guess I need to post up some pictures when all these goodies get installed?
  9. May 19, 2011 at 11:30 PM
    Disorderly
    Disorderly Well-Known Member
    Next time use a torch to heat the manifold stud area until glowing orange. Try to avoid heating the bolt and use vise grips to turn the studs out.
