Broken eyelit for caliper guide pin.. this a huge deal?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rjerics1, Jul 17, 2022.
  1. Jul 17, 2022 at 10:58 AM
    Rjerics1
    Rjerics1 [OP] New Member
    1997 Tacoma
    Stock
    I just did a brake job on my 97 Tacoma and while I was removing a rusty caliper guide pin on passenger side caliper the eyelit snapped off, it had to of been cracked because with minimal pressure while pulling the pin it snapped clean off. I put it all together and drove it and seems fine. Is it a good idea to replace the caliper? Seems everything is solid enough, but unsure...
  2. Jul 17, 2022 at 11:06 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Can’t get another pin?
  3. Jul 17, 2022 at 11:12 AM
    Rjerics1
    1997 Tacoma
    Stock
    I put a new pin in, the issue is what the pin slides through on the caliper. That is broke
  4. Jul 17, 2022 at 2:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The caliper broke must have been a bad casting that your bad luck caused to break at this time.
    The only thing that might happen is the pads could twist enough to cause the caliper to hang up.
    This might happen with the pads in contact with the rotor or not.Might not be a problem you never know.
    Losing the core for the caliper is a pain
  5. Jul 18, 2022 at 7:27 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Don't fart around trying to save a few bucks on your brakes.
    Buy a rebuilt caliper from Pep Boys, O'Reilly, or Autozone. Install it.
    Only then can you drive knowing that the brakes are 100%.:thumbsup:
    SR-71A likes this.
  6. Jul 18, 2022 at 7:52 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    ... are you saying the caliper itself broke where the pin goes through it? And you're driving around like that? :facepalm:
    Bivouac likes this.
  7. Jul 18, 2022 at 8:19 AM
    curth0man
    curth0man Well-Known Member
    Curt
    2001 Toyota Tacoma SR5 4x4
    I'd just replace it, it's fairly cheap and quick job to put a new caliper on. Not worth the risk.
  8. Jul 18, 2022 at 8:32 AM
    Bivouac
    Not sure why the OP had to give this thought.
    I would have had two new calipers ASAP.
