Broken foot rest, long rant...
Discussion in 'Technical Chat' started by MikeS., Jun 19, 2008.
  1. Jul 23, 2012 at 11:55 AM
    LaTechLogan
    LaTechLogan Well-Known Member
    Logan
    Louisiana
    '08 PreRunner Sport
    - K&N intake - Pioneer headunit - 2 Kicker 10" subwoofers & amp - Nokya Hyper Yellow foglights - 18" Magnaflow muffler - Bilstein 5100 shocks set to 0" - Eibach coil springs - 1.5" blocks in back
    Mine broke off as well, less than a year after I got it. I never worried with it bc I figured the replacement piece would be unreasonably expensive. Glad to hear it's not. I'll probably replace mine soon.
  2. Nov 7, 2012 at 8:28 PM
    pmtelt
    pmtelt New Member
    Paul
    So. Cal.
    2010 Tacoma SR5 PreRunner TRD Off Road
    S T O C K ! Yep, S T O C K.
    Well, I just bought a 2010 Tacoma double cab. My foot rest broke off and it looks, scratch that, LOOKED like it. I can't find it now. I think it fell out of the truck. I will be talking to Toyota tomorrow. just to let you know, I found them on line for $4.37 . Just check around if the dealer and the folks that you dealt with flake out on you!:eek:
    [​IMG][/QUOTE]
  3. Aug 11, 2018 at 7:18 AM
    2006TacomaDoubleCabDad
    2006TacomaDoubleCabDad New Member
    Joe
    2006 Tacoma Double Cab / Short Bed
    I had to replace my footrest ... purchase online from a certified toyota dealer ($14 all in). Come with two white posts. Now the challenge to install. I'm thinking about just leaving the original white posts in place and snapping on the new footrest. I do like the idea of shoring up w/ hose clamps. There are three 'legs'. One leg has no support and I'm sure will break again if not supported properly.. I believe my footrest was broken by Toyota when they replace my frame (rust recall). They didn't bother to re-intall correctly. If anyone has replaced recently... would like to know how it went / what to avoid. Seems simple enough. Thanks.
  4. Aug 13, 2018 at 1:26 AM
    Muddinfun
    Muddinfun Well-Known Member
    To remove it from the truck, you just grab it and pull. The white plastic things stay on the metal threaded posts. Unscrew the white things and insert them into the rectangle holes. Yes, they're rectangle. Make sure you line them up right. Then just push the whole thing onto the threaded metal posts. I know your new one is all together, but someday you will need to remove it.
  5. Aug 13, 2018 at 1:39 AM
    Joe
    Done. pretty easy. thx.
    Muddinfun likes this.
