Broken front diff 2018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bestrock970, Jan 28, 2019.
  1. Jan 28, 2019 at 7:34 PM
    #81
    SpeySquatch
    2016 TRD OR DCSB
    Now that’s a skinny
  2. Jan 28, 2019 at 7:34 PM
    #82
    SpeySquatch
    2016 TRD OR DCSB
    If what?
    bestrock970[OP] likes this.
  3. Jan 28, 2019 at 7:35 PM
    #83
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    Cause it’s weak
  4. Jan 28, 2019 at 7:36 PM
    #84
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    Not needed. Good luck with that, hope tour diff doesn't explode.
    GrebTacoma likes this.
  5. Jan 28, 2019 at 7:36 PM
    #85
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Front diff, rear diff, who’s counting?
  6. Jan 28, 2019 at 7:37 PM
    #86
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    JNG and ChronicTaco like this.
  7. Jan 28, 2019 at 7:37 PM
    #87
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    That’s the front diff and center diff.
    Jessrin and JNG like this.
  8. Jan 28, 2019 at 7:39 PM
    #88
    ferntr33
    ferntr33 Well-Known Member
    Definitely would not expect dif gernade with those. Sorry again.
  9. Jan 28, 2019 at 7:40 PM
    #89
    Stocklocker
    17TRDORDCSBAT
  10. Jan 28, 2019 at 7:40 PM
    #90
    eon_blue
    Azusa, CA
    All solid axle fails in this video...granted they're Jeeps so maybe that has something to do with it, lol
    https://www.youtube.com/embed/-_Rewrd8Fq8
    Seems like on at least half of them it's a u-joint (?) failure on either end of the axle
    JNG likes this.
  11. Jan 28, 2019 at 7:42 PM
    #91
    Comato$e
    Comato$e Well-Known Member
    Joshua
    Chicago,Il
    18' MGM OR DCSB
    If OP truck is an off-road then it’s recommended to NOT install the DD for whatever reason . Just a thought idfk
    Mully likes this.
  12. Jan 28, 2019 at 7:42 PM
    #92
    Jay-coma
    British Columbia
  13. Jan 28, 2019 at 7:43 PM
    #93
    SpeySquatch
    2016 TRD OR DCSB
    Well...now I’m getting all paranoid about my diff drop. Be honest fellers. I trail ride and rarely do anything where my wheel gets more than 4” off the ground.
    Should I remove them? (Not trying to hijack thread)
  14. Jan 28, 2019 at 7:45 PM
    #94
    ferntr33
    I was just watching a taco commercial with wheels bouncing all over the place lol.
    tcjacado likes this.
  15. Jan 28, 2019 at 7:45 PM
    #95
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
  16. Jan 28, 2019 at 7:45 PM
    #96
    Mully
    CA
    Over 40K miles on my truck, no DD and I wheel my truck also.
  17. Jan 28, 2019 at 7:46 PM
    #97
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    That's that new 360 degree horizontally pivoting rear axle I've heard about isn't it?
    transworldmoto and JNG like this.
  18. Jan 28, 2019 at 7:46 PM
    #98
    2BeersPlease
    2BeersPlease Well-Known Member
    It's not that it happened. It happened because of his negligence. Then he comes on here pretending he did nothing wrong, asking if anyone else has had this "problem," like it's somehow a manufacturing flaw, then complaining Toyota won't cover it under warranty.
    Take responsibility for your actions instead of trying to blame someone else for your fuck up. It's a common theme in the 3rd gen forum.
    transworldmoto, synaps3 and JNG like this.
  19. Jan 28, 2019 at 7:46 PM
    #99
    eon_blue
    Azusa, CA
    diff drop was not the reason this happened, I refuse to believe that. Diff drops put more stress on the front diff bushings but that's about it. Just means you might have to replace the bushings in 100k miles instead of 200k, who knows.
    All a diff "drop" does is it tilts the diff forward a tiny bit. I suppose if you stacked washers and put a big enough tilt on it, you could argue that it's going to mess with the oil's ability to lubricate the gears properly but no one stacks washers on a diff drop (at least they shouldn't).
    Anyway diff drops aren't worth the trouble IMO, they do very little if anything to help CV angles. Best thing you can do is minimize your suspension lift (~2 - 2.5" max) and use larger tires to gain ground clearance. Larger tires are the only true way to gain clearance anyhow.
    SR-71A, blu92in99, JNG and 1 other person like this.
  20. Jan 28, 2019 at 7:47 PM
    #100
    SpeySquatch
    2016 TRD OR DCSB
    Ever replace your CVs. I don’t want to do that
