Broken front diff 2018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bestrock970, Jan 28, 2019.
  1. Jan 28, 2019 at 8:09 PM
    #121
    SpeySquatch
    2016 TRD OR DCSB
    Are those AllPro sway bar links worth it?
  2. Jan 28, 2019 at 8:10 PM
    #122
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    None of my fins touch, close, but no touchy.
  3. Jan 28, 2019 at 8:10 PM
    #123
    Mully
    CA
    Yes, stock ones will bend. You can get everything online and build your own.
    SpeySquatch[QUOTED] likes this.
  4. Jan 28, 2019 at 8:11 PM
    #124
    eon_blue
    Azusa, CA
    Same, I've had to replace a few axles from leaking boots but such is the price to pay when you weekend warrior regularly. Napa axles are cheap and you really only have to buy them once since they have lifetime warranties.
    Mully[QUOTED] and SpeySquatch like this.
  5. Jan 28, 2019 at 8:11 PM
    #125
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Real question is who installed this guys lift?
    Might want to question that guy.
    JNG and Mully like this.
  6. Jan 28, 2019 at 8:12 PM
    #126
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Why do people go spinning wheels in 4low anyways? :crazy::facepalm::notsure: Yeah, I :turtleride: over rocks and stuff, it’s people who like to :mudding:that usually break stuff or end up going off where they didn’t want to go. No thanks, never broke an axle or CV joint before, even after thousands of off road miles.
    MR E30, JNG and Mully like this.
  7. Jan 28, 2019 at 8:13 PM
    #127
    SpeySquatch
    2016 TRD OR DCSB
    May have to do that
    So with the diff drop spacers I just put a jack under each side (one at a time) loosen bolt, take out spacer. Insert bolts and retorque to 90ft/lbs right?
  8. Jan 28, 2019 at 8:14 PM
    #128
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    So...that’s definitely some rapid unauthorized disassembly if I’ve ever seen it. And I’ve seem some shit go sideways before. Like seen a maritime diesel engine spew parts all over an engine room bad.
  9. Jan 28, 2019 at 8:15 PM
    #129
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Or don’t install them. Both times I’ve tried to run diff drop spacers I’ve ended up with vibrations. Pulled them and ran 80k miles with zero issues
  10. Jan 28, 2019 at 8:16 PM
    #130
    OnHartung'sRoad
    Tie rod going in and out of the side of my friend’s V8. Drove it home that way, too!
  11. Jan 28, 2019 at 8:16 PM
    #131
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Dont forget to check them again after a short drive. Also check all the bolts on the diff.. I've found mine loose after seeing a guys explode. Checked mind and it wasn't to spec. Tight. Just my 2 cents I now check after every oil change.
  12. Jan 28, 2019 at 8:20 PM
    #132
    eon_blue
    Azusa, CA
    no need to jack up the truck, you can do it with the tires on the ground. Just do one bolt at a time, pull the bolt out and remove the spacer. Put the stock bolt back in (my diff drop kit came with longer bolts so I kept the old ones just in case I ever took it out).
    I don't know if you can use the longer bolts without the spacer, might be able to or they might be too long.
  13. Jan 28, 2019 at 8:29 PM
    #133
    SpeySquatch
    2016 TRD OR DCSB
    Spec says 100ft/lbs
  14. Jan 28, 2019 at 8:31 PM
    #134
    SpeySquatch
    2016 TRD OR DCSB
    Anyone know what size the stock diff mount bolts are for the front?
  15. Jan 28, 2019 at 8:37 PM
    #135
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Thats bullshit. Find another dealer.
    JNG, 98tacoma27, JCOOR and 1 other person like this.
  16. Jan 28, 2019 at 8:47 PM
    #136
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    No warranty NP, just use this stuff. The way this stuff works is out of this world!
    SR-71A likes this.
  17. Jan 28, 2019 at 8:51 PM
    #137
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    The axle broke because the CV locked up due to over extension. Not Toyotas fault. Sloppy installation of aftermarket parts are the culprit.
    Note : After a lift of any kind you should let your suspension hang full droop on the lift and try to fully spin the front wheels if they lock up in any position that needs to be fixed, if not this is the result.
  18. Jan 28, 2019 at 8:53 PM
    #138
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
  19. Jan 28, 2019 at 9:01 PM
    #139
    Saltwatertaco
    Saltwatertaco Active Member
    Brandon
    2006 Silver Taco TRD SR5 4x4
    Level kit Kevlar Painted Fenders
    :itllbuffout:
    A little too much :bikewhoops: for you my friend.
    Seriously though, if you're going to pass your bad luck onto toyota dealership and they dont buy it, dont go around telling others and looking for sympathy... you're just going to make yourself look dumb.
    JNG likes this.
  20. Jan 28, 2019 at 9:45 PM
    #140
    Sgt BadA
    Sgt BadA Active Member
    Fort Worth TX
    2018 TRD offroad quicksand
    Icon 2.5 coilovers and Dakar leafs, caliraised ditch lights, TRD intake, 16x8 TRD Trail Team rims with 33in BFG KO2 tires
    Sounds like driveline wind up. Driving in 4lo all the time isn’t a good thing. Especially if traction isn’t a problem. At least from what the OP explained he makes it sound like he drove like that for awhile.
    JNG likes this.
