Broken front diff 2018
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bestrock970, Jan 28, 2019.
  1. Jan 28, 2019 at 10:40 PM
    #141
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    That guy needs to air down those tires...
  2. Jan 28, 2019 at 10:45 PM
    #142
    svdude
    svdude Well-Known Member
    jonathan
    This always cracks me up... We have a truck that is 4wd, has a locker, advertised for off road use, and even has a cool off road sticker on the truck. The off road goodies on the truck will never be used on pavement. But driving the truck on other than pavement voids a warranty claim.
    OP, I would escalate this up to Toyota because that should be covered... Just my opinion.
    Taconator_ and HappyGilmore like this.
  3. Jan 29, 2019 at 3:24 AM
    #143
    Drtyjerz47
    Drtyjerz47 New Member
    Luis
    SOLD 17 4Runner SR5P
    I love hearing how open and honest people are with the stealership who is never open and honest with the consumer.
    Now your eating the cost.
    If you learned something from this experience it was worth it
    JNG likes this.
  4. Jan 29, 2019 at 3:45 AM
    #144
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    "the CV locked up due to over extension"
    CV = Constant Velocity joint, right?
    I don't understand. Could someone explain?
    (Wouldn't that be just like a locking hub?)
    Thanks,
  5. Jan 29, 2019 at 3:49 AM
    #145
    HTeeAre
    HTeeAre Well-Known Member
    2016 Quicksand TRD OR 4x4
    From my limited off roading and 4wd knowledge, 4lo and WOT usually do not mix. 4lo outputs a lot of torque and you going WOT most likely caused an overload of power and BAM something gave. Whenever I do go into 4lo it’s to pull someone out who’s stuck in sand/mud. Steady pressure on the gas to prevent tire spin and get them out slowly but surely, or when I’m climbing a hill. Which once again I’ll apply steady rising pressure to avoid tire spin and maximize the use of the power. Have never gone WOT in 4lo and don’t plan to.
    jsinnard, 2016Tacoman and JNG like this.
  6. Jan 29, 2019 at 4:02 AM
    #146
    98tacoma27
    Ben
    Not Beech Creek
    No, it's not like a locking hub. The joint is always "locked", hence "constant velocity".
  7. Jan 29, 2019 at 4:06 AM
    #147
    Tacorific
    NE Iowa
    So how would that break a Diff?
  8. Jan 29, 2019 at 4:11 AM
    #148
    98tacoma27
    Ben
    Not Beech Creek
    4lo has a tremendous amount of torque. When you get a wheel spinning at WOT and then stop that wheel dead in it's tracks, all that energy has to go somewhere. And that somewhere is usually the weakest point which is typically the gears in the diff. The CV didn't kill the diff. Just like the fall doesn't kill you, it's the sudden stop at the end that does it.
  9. Jan 29, 2019 at 4:18 AM
    #149
    Tacorific
    NE Iowa
    Thanks, I get that.
    But he inferred that:"the CV locked up due to over extension" is what caused the Diff to fail. That is what I'm trying to understand.
  10. Jan 29, 2019 at 4:27 AM
    #150
    16tacoblue
    16tacoblue Well-Known Member
    2016 sport taco
    Colored chrome fenders name plates & tailgate emblem flat black.
    welcome and d@#$ !!
  11. Jan 29, 2019 at 4:45 AM
    #151
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    CV joint, (and U joints, etc) can internally bind if articulated more than their capability. This may not be apparent driving normally and only becomes apparent if the suspension extends to its maximum. When this happens, the joint no longer rotates, and becomes more like a rigid bar bent at X degrees.
    It's easier to imagine a standard U joint. Works fine at 0 deg or 10 deg, but imagine trying 40 deg of misalignment. The yokes interfere and it no longer wants to turn.
    Now, all that said, I have NO IDEA what the allowable angle is for these front CV shafts, and how they behave when exceeding their allowable maximum angle... just trying to answer the question of what does 'CV locked up' mean... make sense?
    TRD493 and bulalo like this.
  12. Jan 29, 2019 at 4:49 AM
    #152
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I think someone doesn't understand what 4 low does.
  13. Jan 29, 2019 at 4:53 AM
    #153
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    Driving in 4lo for long periods of time is not a problem. I have done it on every Toyota I've had. Likely hundreds of miles a year in 4lo. I do it to take advantage of the gearing. Driving in 4lo is not the cause of the failure, after all 4lo is just a different set of gears.
  14. Jan 29, 2019 at 5:15 AM
    #154
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    this reminds me of the guy from a while back "driving up this long driveway" and grenaded his diff
    TacoZim and hiPSI[QUOTED] like this.
  15. Jan 29, 2019 at 5:23 AM
    #155
    Tacorific
    NE Iowa
    Thanks, You guys aren't getting my question. I get how CV joints and U joints work. I even understand how and what causes them to bind. I should have explained earlier that I am a retired mechanical Engineer, who got tired of not making any money as an auto mechanic.
    I've shelled out Diffs, twisted the splines off of axels, even fractured an axel once, (although it had a preexisting stress fracture). What I don't understand is how a "locked up due to over extension" CV joint, can cause a cast iron front diff housing and axel to break the way it did.
  16. Jan 29, 2019 at 5:26 AM
    #156
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    Didn't you hear the Birfield explode in @Stocklocker's first video? Solid axles don't give you an automatic free pass to wail on your junk.
  17. Jan 29, 2019 at 5:57 AM
    #157
    slowtacotruck
    slowtacotruck Well-Known Member
    17 offroad
    stuff
    Time for a Dana 60!
    Jay-coma likes this.
  18. Jan 29, 2019 at 6:25 AM
    #158
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's because it didn't. The guy who posted that was wrong.
    Skydvrr, ColoradoTJ and 98tacoma27 like this.
  19. Jan 29, 2019 at 6:27 AM
    #159
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    he said he went WOT in 4 lo, maybe had something to do with it?
    JustMeMyselfAndI and JNG like this.
  20. Jan 29, 2019 at 6:29 AM
    #160
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    No I didn’t because his first video is a Jeep Patriot and they don’t have birfs..;)
    DaveInDenver[QUOTED] likes this.
