Broken Handle
Discussion in '1st Gen. Tacomas (1995-2004)' started by SavvyK, Jan 6, 2017.
  1. Jan 6, 2017 at 7:05 AM
    SavvyK
    SavvyK [OP] New Member
    Savannah
    2002 Tacoma TRD
    Camper Shell
    Hello everyone. I am a new member and I am in quite the pickle!
    Today, I went to open my unlocked drivers door. It was 3 degrees outside, so it must have been frozen. When I pulled on the handle, something snapped. The handle now just lifts freely, it broke off the hinge or something. Obviously, I am not very mechanically inclined, so bear with me on the description!
    The reason this is such an issue, is because I can not enter the truck from the passenger side. For some time now, the lock has been broken on that side. It is stuck in the locked position and I am unable to unlock it from the inside or out. I haven't had the time or resources to get that problem fixed, so I just never have a passenger!
    Any tips or tricks for how to open my drivers door without the use of the handle?
  2. Jan 6, 2017 at 7:13 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Sounds like you need a locksmith to open the passenger side, unless you can grab the broken part of the handle with some pliers or something to get the latch to work.
    I have some 1st gen door handles you can have, send me a pm, you pay the postage...
    And welcome to TW!
  3. Jan 6, 2017 at 9:47 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    A rock (or the ceramic chunk form a spark plug) and a new window from a salvage yard is probably cheaper than a locksmith... I remember AAA charged me like $80 for 10 seconds of work to pick my lock when I locked the keys in my 97 5 lug.:frusty:
    Figure out which ever window is the cheapest (and easiest) to replace and smash it. Since you need to open up the door (I mean take it apart, not just "open" it, lol) anyway to replace the door handle, you might as well smash the driver's window.
    A locksmith or a shop can replace your passenger side lock and re-key it to match your keys, too.
  4. Jan 6, 2017 at 10:13 AM
    nmgman
    nmgman Member
    dave
    2001 tacoma
    Old School likes this.
  5. Jan 6, 2017 at 10:28 AM
    NM Lance
    NM Lance Well-Known Member
    Time for a sunroof! :sawzall:
    Joking...
    If you haven't already gained access, get a pair of pliers and try to grab onto whatever is remaining of the handle. Try this before breaking any glass! If it's 3 degrees outside, the last thing you want is to break a window.
    These handles are cheaply made, and the OEM handles are $75 online. You didn't mention, but if you have a sliding rear window, see if you can pop it open by sliding the glass with your palms.
  6. Jan 6, 2017 at 6:18 PM
    58jake
    58jake Active Member
    Jake
    Three Forks, Valley Center, Kea'au
    If its that cold, just break the handle out (try not to damage the door or paint), and gain access to the rods and open it up.
  7. Jan 7, 2017 at 2:31 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    Yep I agree with the glass breaking. IF all else fails. Iirc, the door glass is cheaper than the wing Windows(if you have an extended cab). Probly cheaper than the rears on dc's too. Plus they're not that hard to put in a new one. Also, the cheap handles will work, but are limited lifespan. I highly suggest oem handles. I've tried a few different brands, and they all fail fairly quickly. If you're tight on budget, get the cheapies, but also start saving and immediately buy oem when you can. Then swap and save the cheap one for a backup.
  8. Jan 7, 2017 at 3:13 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    If you can afford the OEMs, do that. I bought some cheap ones off of Amazon, and they aren't great. They work, but feel like they're going to break every time I open the door.
    When I broke the original driverside handle, there was still enough plastic for me to lift to open the door.
  9. Jan 7, 2017 at 5:22 AM
    pofarm
    pofarm Well-Known Member
    Greg
    SW MO
    1996 Taco
    Just information...the black handles are plastic. The chrome ones are metal. Get chrome if you can.
  10. Jan 7, 2017 at 5:27 AM
    Old School
    They're all plastic!o_O
  11. Jan 7, 2017 at 5:29 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    Nope! I just picked up a chrome one for my 96. The handle is metal. The surround is plastic.
  12. Jan 7, 2017 at 5:30 AM
    Old School
    The attachment points are still plastic!:notsure:
  13. Jan 7, 2017 at 5:32 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    The plastic handle is what usually breaks, right at the attachment points. That is the weakest area.
  14. Jan 7, 2017 at 5:33 AM
    Old School
    I went through a number of chrome handles, take the chrome off, it's still plastic...
  15. Jan 7, 2017 at 5:39 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    Whatever. I know the one I have is metal. It's even substantially heavier than the black one I have.
  16. Jan 7, 2017 at 5:40 AM
    Old School
    :worthless:
    :laugh:
  17. Jan 7, 2017 at 5:44 AM
    pofarm
    Greg
    SW MO
    1996 Taco
    What is that going to prove? You can't tell chrome plastic from chrome metal in a picture. :notsure:
  18. Jan 7, 2017 at 6:58 AM
    Old School
    :deadhorse:
  19. Jan 7, 2017 at 8:36 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    If only they made metal ones. I'd buy in a heartbeat.
  20. Jan 7, 2017 at 9:52 AM
    NM Lance
    Which brand did you buy? Was it OEM, or something else? Shit, now I need one. Damned cold weather.
