broken lca bolt
Discussion in 'Suspension' started by hard2kill, May 6, 2012.
  1. May 6, 2012 at 11:39 AM
    hard2kill
    hard2kill [OP] Well-Known Member
    Rhinebeck NY
    06 4door trd sport white 6spd
    ...315's,2in bora wheel spacers,safari snorkel,wheel spacers,bruteforcefab rear bumper and sliders,afe filter,hi-lift jack,5100 with OME 886 & 1/2in spacer,allpro expo's,icon 10in rear shox,flip kit,ss brake lines,cobra cb,fog light mod,yellow fogs,weathertech mats,fullsize spare tire and extra sport rim,tinted windows,aeroturbine 2525 muffler dumped over axle...rear diff breather mod...removed factory spare...removed 2nd air filter...THULE roof rack and fairing....bud builts front to back,allpoo front bumper,BAMF lca skids,overland Offroad roof and bed racks,
    so i installed my lr uca's and went to get an allignment to find 1: the guy had no idea what he was doing and 2:my pass side front lca bolt is broke :( anyone else have this problem ? looks like a pia to fix
  2. May 6, 2012 at 12:42 PM
    hard2kill
    Rhinebeck NY
    cant find just a bolt? do i need to go to toyota,buy a used complete lca,buy bushings and bolts from somewhere,or can i just get a bolt?
  3. May 6, 2012 at 12:47 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You can get just the bolt. I just bought it from Camelback Toyota along with LCA bushings. If you call the stealership, they should be able to hook you up. Depending on which one got broken, it should be around $10 - $20.
  4. May 6, 2012 at 3:32 PM
    hard2kill
    Rhinebeck NY
    thanx man....its the front lca bolt on the pass side....was yours hard to get out? i never even knew mine was broke till i tried to adjust it :(
  5. May 6, 2012 at 3:43 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    FOX 2 1/2" CO's STOCK UCA's - They used to be Icons! Icons suck!!! TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I had to replace both LCA's due to frozen bushings when I installed my UCA's. :mad: $1100 later, I have a brandy new front end.
  6. May 6, 2012 at 3:54 PM
    hard2kill
    Rhinebeck NY
    thats insane on a 2008!!!! i refuse to spend that...
  7. May 6, 2012 at 7:32 PM
    Pugga
    Massachusetts
    Mine won't come out, I'm cutting the bolts to get them out. Same thing happened to me, I took it in for an alignment and the tech wouldn't touch it because he was afraid everything would be frozen up. He was right... :(
    You can just replace the bushings but the stealerships won't do it. Up north, they just replace the whole LCA. I bought new bushings and will do it myself. I refuse to pay out the ass for Toyota's inability to put grease on parts like they should have.
