Broken leaf spring on 97 Tacoma 4X4
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4Xtruck, Apr 10, 2021.
  1. Apr 10, 2021 at 11:16 AM
    4Xtruck
    4Xtruck [OP] Well-Known Member
    Southern California
    1997 2.7 4WD Xtra cab
    The center leaf spring on the driver's side broke, so I need to replace my leaf springs. Going online, I see many different products, yet I don't know how to compare them. I see lifts of 1.5" - 4". Warranties are all over the place, from nothing to lifetime. I don't know what is stock on this truck, and the OEM part #s are discontinued. I'd appreciate any help you can offer to help me choose replacement springs. It doesn't look like 2.7 engine, Xtra cab and manual transmission affect the choice.
  2. Apr 10, 2021 at 11:22 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
  3. Apr 10, 2021 at 11:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Check out General Spring of Kansas City.
    You can get direct replacement or Heavy Duty if you use your Truck to haul Cargo.
    They are my Go To Spring People
    0xDEADBEEF likes this.
  4. Apr 10, 2021 at 3:58 PM
    JC34X4
    JC34X4 Well-Known Member
    J
    Minneapolis
    96 Tacoma 5spd 4x4 single cab.
    I got general spin
  5. Apr 10, 2021 at 4:00 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  6. Apr 10, 2021 at 6:27 PM
    SkunkMan17
    SkunkMan17 Jerry-rigging everything
    Owen
    Montana
    1997 Tacoma RC 4x4
    Tasteful modifications :)
    General spring. Ordered both my new leafs on there. You’d be surprised how well your truck will ride with new leafs. I would also buy a passenger and driver set, not just one side, as you will have an uneven height in the rear If you just do one side.
  7. Apr 18, 2021 at 6:39 AM
    4Xtruck
    Southern California
    I just realized I was never notified of any posts. Thank you for your responses. I'll see what shipping is for General Spring. Anyone have any installation tricks to make the job easier?
  8. Jul 3, 2021 at 8:36 PM
    4Xtruck
    Southern California
    I finally got around to replacing these leaf springs, and I did go with General Springs. Yes, it was a pain to do, and I had to replace the front bolt on both sides. I do have a questions, though. The springs are thicker than stock, so the parking brake cable sits on top of the left leaf spring. Is this a concern, and what do you recommend to fix it. Maybe I can add an M8 coupling nut at the bottom of the center bolt and then raise it up with a piece of M8 threaded rod. I could also put insulation around the cable where it crosses the spring and not raise the center bolt. What are your thoughts?
  9. Jul 4, 2021 at 12:08 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Several ways to go .
    Pictures would help . Much easier to figure out looking at things
    Extend the bell crank to get what you need.
    Raise where the cable attaches to the axle.
    Pretty much do what you need to make it work.
  10. Jul 4, 2021 at 3:44 PM
    4Xtruck
    Southern California
