Broken leaf spring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Mar 9, 2013.
  1. Mar 9, 2013 at 2:05 PM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Started noticing a new squeeking and occasionally light clanking sound late this week. I got to looking at it today and found the middle leaf on the driver's side leaf spring pack is broken.
    I'm long out of warranty. I just called a local dealership to ask for an estimate on the leaf spring TSB out of warranty. The price seemed a little crazy.
    Anyone here had to deal with a broken leaf spring on these trucks? How much did it cost to fix?
  2. Mar 9, 2013 at 2:08 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    if your out of warrenty why not just upgrade to a set of aftermarket rear springs? ex: allpro, deaver, etc.
  3. Mar 9, 2013 at 2:08 PM
    PA452
    Western PA
    Ballpark how much would I be getting into with that?
    I don't haul anything really heavy, and in fact I rarely haul anything anyway. I don't go off-roading. For the past couple years it's pretty much been used as a commuter.
  4. Mar 9, 2013 at 2:13 PM
    trooper12
    trooper12 Well-Known Member
    Spencer
    Trabuco Canyon, CA
    2012 SR5 PreRunner
    maxtrac 4" lift spindles, wheelers 1.5" 3 leaf pack. nothin special...
    Allpro standard: $399
    Allpro Expo.:$429
    Deavers: $624.95
    Wheelers (alcan): $599
  5. Mar 9, 2013 at 2:22 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    I'd go with Wheelers no lift packs.
    You could always buy some junkyard leaves with the same width and length and build yourself a bastard pack.
    Just pull your broken middle leaf and the middle leaf on the other pack out and swap in something similar. Super cheap in that regard.
  6. Mar 9, 2013 at 5:49 PM
    PA452
    Western PA
    Yes, I should have added that I'm not looking to lift it. Stock height works for me.
  7. Mar 9, 2013 at 7:17 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    This is the more expensive of the options I suggested and arguably better but I still maintain that throwing in some leafs from a junk yard pack isn't a bad way to go.
  8. Mar 9, 2013 at 7:32 PM
    PA452
    Western PA
    I'd like to go a little cheaper than that. Anyone know of any stock height aftermarket spring packs that would run $200 or less per side?
  9. Mar 9, 2013 at 7:34 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    You can get a pair for that price, check the Buy/Sell/Trade section. Mine broke and that's where I bought mine.
  10. Mar 9, 2013 at 7:47 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Check with your local tacoma world group.
    I am sure someone has lifted theirs and now has some stock ones sitting in their garage.
  11. Mar 9, 2013 at 7:48 PM
    PA452
    Western PA
    I'd like to stay away from the stock springs since they seem to be prone to breaking.
  12. Mar 9, 2013 at 8:57 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Mine aren't prone to breaking, and will be available in eastern PA in about a week.
  13. Mar 10, 2013 at 7:42 AM
    PA452
    Western PA
    From what I read a good portion of all the stock springs have this problem eventually.
  14. Mar 10, 2013 at 8:34 AM
    Utard
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Just take your old one to a local spring shop and have one custom made.
    Might be hard to find a stock aftermarket one? :rolleyes:
    But I don't see very many threads at all about broken leaf springs. Even if it does cost you $50 every 5 years that pretty damn cheap.
  15. Mar 10, 2013 at 8:43 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Where is the crack on the leaf? If it's from the center bolt hole, then the crack is caused by undertorqued U-bolts from the factory. It also means an OEM leaf pack will be OK if you torque the U-bolts correctly (73+ ft-lb).
  16. Mar 10, 2013 at 6:56 PM
    PA452
    Western PA
    It's broken in two places. One break is in the center, and the end seems to be broken too.
  17. Mar 10, 2013 at 6:57 PM
    PA452
    Western PA
    Aftermarket but stock height.
  18. Mar 10, 2013 at 7:02 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I don't know of any other stock height packs but from where I'm sitting 500 isn't much more than 400 and you might mention you're from TW to get a little discount.
  19. Mar 10, 2013 at 8:19 PM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    If ya change your mind, they will be available for pretty cheap.
