Broken "light well" bolt installing UnderCover Tonneau
Discussion in 'Tonneau Covers, Caps and Shells' started by RideTacoRide, Jun 17, 2014.
  1. Jun 17, 2014 at 8:04 PM
    RideTacoRide
    RideTacoRide [OP] New Member
    So for my first mod to my 2014 Double Cab Prerunner (besides Weathertech floormats) I decided to get an UnderCover Tonneau. All was going well until one of the "light well" bolts broke off while attempting to install the rear mounting bracket for the undercover. The bolt I am referring to is the one on page 6 of the Instructions (pictures C & D). The bolt broke pretty close to the head so I'm now trying to figure out how I'm going to get it out :confused:
    Anyone have a suggestion? Also, does anyone know what the precise name of this bolt is or a part number so that I can get a replacement?
    Thanks!
  2. Jun 17, 2014 at 8:57 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    1.) Center punch the bolt that is still in the hole.
    2.) Get a small left hand drill bit and drill a hole in the center. Go slow and easy, let the drill do the work. Note: this may back it out when the bit starts cutting.
    3.) If drilling doesn't back out the remains, Get an easy out and use it to remove the bolt.
    Use one on the other side of the truck to figure out the size. Remove it and go to the hardware store.
  3. Jun 18, 2014 at 9:15 PM
    RideTacoRide
    Thanks! I'll give it a go.
  4. Jun 19, 2014 at 12:54 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Remember to just go slow and take your time.
  5. Jun 22, 2014 at 12:36 PM
    RideTacoRide
    Update: Bolt is out and the Undercover Tonneau is installed! :)
    Thanks again!
