broken right rear shock
Discussion in 'Suspension' started by nurseboy, May 26, 2010.
  1. May 26, 2010 at 9:01 PM
    nurseboy
    nurseboy [OP] Well-Known Member
    Jan
    Riverside, Ca
    So here is the story...quick version
    Went over dip at regular speed few days ago, havent drove the truck since then. Heard clunking noises after...Heard the noises again on way to work and saw rear right shock broken (pic below). I have the toytec ultimate lift kit and was installed about 1 year ago. Never had problems until now. Is this fixable, should i contact toytec, and/or and I screwed?
  2. May 26, 2010 at 9:03 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    are they new rear shocks(5100s), and do you just have a AAL in the rear?
  3. May 26, 2010 at 9:24 PM
    nurseboy
    Jan
    Riverside, Ca
    I mentioned I have the toytec ultimate lift kit...
    -----TAC-AL - ToyTec Rear "long" add-a-leafs featuring anti friction pads for quiet ride
    -----Extended length Bilstein 5100 rear nitrogen gas shocks for optimum performance on and off road
  4. May 26, 2010 at 9:26 PM
    ktmrider
    Junk
    Yea those shocks can accommodate that amount of lift so I would talk to toytec cause that should not happen
  5. May 26, 2010 at 9:48 PM
    nurseboy
    Jan
    Riverside, Ca
    Yea I just got done emailing them not to long ago and included the picture above. I haven't done any extreme off roading or flex the front or rears at all. Has anyone had this problem? If yes did toytec replace the shock or do you guys think this fixable. I am just trying to see what to expect tomorrow after work.
  6. May 26, 2010 at 9:51 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    That should be a warranty thing, they shouldn't break, just wear out.
    Make sure your warranty replacement shock(s) isn't over-torqued during install...
  7. May 26, 2010 at 9:53 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    The shock you had break, could have simply had a flaw in the rod which in turned led to the failure. It wouldn't be the first time its happened, although it isn't very common. The good thing is, you are covered by a lifetime warranty with the billy's.
  8. May 27, 2010 at 12:50 AM
    nurseboy
    Jan
    Riverside, Ca
    I haven't had time or in the right place to check the warranty (I'm at work because i work graveyard). Do you know if I should deal with toytec or would I have to be contacting the manufacturer for this problem?
  9. May 27, 2010 at 12:52 AM
    SC4333
    Grant
    San Antonio, TX
    I'd say start with Toytec and then go from there. What are you using as a replacement in the mean time? Did you just remove the shock for now?
  10. May 27, 2010 at 12:56 AM
    nurseboy
    Jan
    Riverside, Ca
    I haven't done anything... iI is sitting outside in the parking lot. I took that picture right when I got to work...I'm going to have to drive it like that on the way home...
  11. May 27, 2010 at 12:58 AM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    lol i wouldnt have seen the problem without the red arrow :rolleyes:
    that should definately be covered under warranty
  12. May 27, 2010 at 1:02 AM
    SC4333
    Grant
    San Antonio, TX
    Well that sucks. See if you can some how secure the shock body to something in order to prevent it from coming in contact with your tire on the ride home. You should be fine without it, but I wouldn't go do anything to crazy on the way home.
    Something you might be able to do, if there is a maintenance guy on duty, you might be able to borrow some simple hand tools to remove the lower bolt and get that shock body out of there. Just some food for thought.
  13. May 27, 2010 at 1:03 AM
    McJosh
    McJosh avidoffroad.com
    Josh
    Chandler
    2005 Reg. Cab 5 lug Tacoma
    Pioneer AVH-p2300DVD, 12" Memphis sub and Alpine MRP-M650 amp, 32" BFG AT tires and KMC wheels, tinted windows, satoshi grille w/ stainless steel mesh, Avid front & rear tube bumpers, Cobra wx75 CB with 3' firestik, GaragePro bucket seats, FlowMaster 40 series, aFe CAI, Black head lights, LoJack and Autopage alarm installed, Avid sliders.
    That sucks. :( hopefully it gets taken care of.
  14. May 27, 2010 at 8:13 AM
    nurseboy
    Jan
    Riverside, Ca
    not to seem mean and pushing any further advice out of the way, but I've listed and answered this twice already....
