Broken Shift Cable
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Arsey51, Jul 19, 2019.
  1. Jul 19, 2019 at 5:25 PM
    Arsey51
    Arsey51 [OP] New Member
    I inadvertently drove over one end of a log that was hidden by dirt on the trail. The other end shot upwards between the transmission and exhaust manifold. It struck the shifter cable and jerked the transmission into Park HARD. It bent the shifter cable and also broke the leads on the downstream o2 sensor. I replaced the parts, but when the transmission is in Drive it will only go into 3rd and 4th gear. Automatic shifts up or down between those 2 gears while moving are abrupt.... Harsh, actually.
    The fluid looks good... no filings or cloudiness. It was recently serviced.
    Is this something out of adjustment, or is there a major problem that requires a rebuild? Any thoughts? Anyone had a similar issue?
    2013 Tacoma Prerunner
    137000 miles
  2. Jul 19, 2019 at 5:43 PM
    FishingPups
    FishingPups Well-Known Member
    Barry
    2014 Tacoma TRD Sport Access Cab
    Prerunner, Towing Package, Convenience Package, Tonneau Cover
    Thoughts: UGH. $$$$$
    There ain't no telling what all has been screwed up in that situation. It could have hit something else that you don't even know about yet. Good luck.
  3. Jul 19, 2019 at 6:08 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Can you manually shift the transmission into 1st or 2nd?
  4. Jul 19, 2019 at 6:19 PM
    Arsey51
    Yes.
  5. Jul 19, 2019 at 6:21 PM
    Arsey51
    I agree....UGH $$$$$
  6. Jul 19, 2019 at 6:23 PM
    FishingPups
    Barry
    You are doing the best thing by asking around here. But it might take a long time to get this one figured out. Stayed tuned. Lots of smart 4x4'ers on here.
  7. Jul 19, 2019 at 7:12 PM
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    It could possibly be that some wiring/harness got damaged.
    For example, if the transmission solenoid #1 wiring to the ECU got damaged, the ECU goes into fail-safe mode using solenoid #2 to make the transmission still useable with 3rd & 4th gear, with lower gears selectable manually by the shift lever.
    http://www.autoshop101.com/forms/h16.pdf page 15
    Jimmyh likes this.
  8. Jul 19, 2019 at 8:22 PM
    Arsey51
    Wow..... outstanding! Thanks!
  9. Jul 19, 2019 at 8:46 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Maybe @gearcruncher will chime in with thoughts he is the transmission god!
    gearcruncher likes this.
  10. Jul 20, 2019 at 4:49 AM
    gearcruncher
    Canadain bumper technician
    Thanks for paging me Jimmy :thumbsup:
    Next thing I would be looking at is if the truck will start in park and Neutral . Can you remove the keys easy when in park ?
    While you are in your driveway , If you go through all the gear ranges with the shifter , does the illuminated dash correspond with the gear you have selected ? Try going from park all the way down to the lowest gear range to see if the dash matches what you shift to on the floor shifter .
    Sounds to me like it may now be out of adjustment becuase of hitting the log or something is bent
    If the transmission computer doesnt know what gear you are in , the transmission will be in limp home mode . Limp home mode is a protective measure built into the computer in your truck to prevent further damage to the transmission . It will shift hard and you will not get overdrive until the shifter is re- aligned .
    If you scan for codes , I will bet you get an error code for the Nuetral safety switch , not because the switch is bad but becuase the shift cable is bent .
    Slide under the truck and have a good look at everything that controls the shifter cable .
    Use the links provided below to figure out if something is bent .
    https://www.customtacos.com/tech.ol...6toyrm/06toypdf/06rmsrc/rm2006ta/02700610.pdf
    https://www.customtacos.com/tech.ol.../06toyrm/06toypdf/06rmsrc/rm2006ta/027010.pdf
    https://www.customtacos.com/tech.ol...06toyrm/06toypdf/06rmsrc/rm2006ta/0280035.pdf
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    As mentioned above , wires could have also been tweaked . A computer scan will tell you for sure
    Jimmyh, FishingPups and Muddinfun like this.
