Broken side camper top window, what are my options ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bamahoyt, Feb 19, 2017.
  1. Feb 19, 2017 at 12:02 PM
    Bamahoyt
    Bamahoyt [OP] Well-Known Member
    Ted
    Knoxville, TN
    2014 TRD Sport DC LB 4x4
    Well I was putting new weather stripping on my camper top that I got and I thought I had cleared the windows when I put it on its side but it sat on one of the handles and the window shattered. I am wondering what my options are for getting a new piece of glass or a window. Any one done this and what was the cost to fix. Pretty frustrated with myself right now and don't have a fortune to spend on this camper top. I have searched several sites and haven't found any side window replacement options. Seems like everyone has to replace their rear windows. Thanks!
    scottalot likes this.
  2. Feb 19, 2017 at 12:09 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    1) Call a glass shop.
    2) Call a local dealer for that shell manufacturer.
    scottalot and DustStorm4x4 like this.
  3. Feb 19, 2017 at 12:33 PM
    Bamahoyt
    Ted
    Knoxville, TN
    I believe its an innovation camper top which is no longer in business so i'll call a glass shop
  4. Feb 19, 2017 at 12:42 PM
    TroutBum
    TroutBum Well-Known Member
    Michigan
    06 SR5 AC 4x4 Sold, 17 Sport 6MT DCSB, 2020 OR DCSB
    Leer 100R
    You might be able to order that window from another brand shell - just need to find a dealer that's willing to help. I've broken them before as well, not hard to change out if you can find the right size.
    DustStorm4x4 likes this.
  5. Feb 19, 2017 at 12:43 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    pretty sure its just straight forward tempered glass so it should be any hardware store glass shop can cut you one, you don't need a factory glass shop
  6. Feb 19, 2017 at 12:43 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Thanks for the input. What does the whole side window typically run you to replace at a dealer? I wish it was super easy but it looks like the window frame is tack welded at the joints so I am not sure how id get the replacement glass in there because it also needs 2 holes cut for the handles since it is a flip up window
  7. Feb 19, 2017 at 12:48 PM
    TroutBum
    Michigan
    Leer 100R
    I think it was around $150.
  8. Feb 19, 2017 at 12:48 PM
    Bamahoyt
    Ted
    Knoxville, TN
    This is the side window that broke on the camper top.
  9. Feb 19, 2017 at 12:49 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Fiberglass the hole shut with a reinforced recess and mounts for rotopax cans.
  10. Feb 19, 2017 at 3:02 PM
    Bamahoyt
    Ted
    Knoxville, TN
    I don't want to lose the window but thanks for the idea
  11. Feb 19, 2017 at 3:22 PM
    iwagner
    iwagner Well-Known Member
    Washington
    2002 Tacoma 2.7l 5spd
    I had the same issue with mine. Unbolted it and took it too a local glass shop and they put new glass in for about $130
  12. Feb 19, 2017 at 3:39 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Ok, was it a auto glass shop?
  13. Feb 19, 2017 at 6:51 PM
    iwagner
    Washington
    Yes, it was Associated Glass. They had experience with this issue, my topper company was out of business
  14. Feb 19, 2017 at 7:55 PM
    Maestro
    Maestro Well-Known Member
    The Master
    The windows are largely standard - there are only a handful of sizes and types - and are shared among different manufacturers. You should be able to do a search - follow it past the top hits and you will eventually find a parts company that sells complete window units (and maybe just window sections). Try RADCO to start?
  15. Feb 25, 2017 at 6:44 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Well I had a shop put in a plexi-glass window for now because it was really cheap but they ended up putting my handles on wrong and drilled the holes in the wrong spot and it cracked the glass when they tightened the handles so now I am on the search again. I have gotten 3 different quotes to replace with tempered dark grey glass and all were around $200 and I am just not about to spend that for a window in a camper top I spent $150 on. I'll probably find someone who will do a lexan replacement for me but not sure. Haven't been able to find a single online dealer that carries camper top windows.
  16. Feb 25, 2017 at 6:49 PM
    medic2230
    Murph
    Bama! Roll Tide
    H moulding from JC Whitney and tinted plexiglass. You lose the door but regain use of the top. I did it on a leer shell once that I needed done quickly.
    I had bought the shell for $100 and wasn't going to spend a fortune on fixing it.
  17. Feb 25, 2017 at 7:00 PM
    Bamahoyt
    Ted
    Knoxville, TN
    Love the though of that. I'll look into that for sure! how'd you make your template and do you have any pictures?
  18. Feb 25, 2017 at 7:29 PM
    medic2230
    Murph
    Bama! Roll Tide
    Looked at the specs on the H channel and traced the window cutout then subtracted the amount I needed for the moulding to go around the window. Popped right in and didn't have the first leak.
  19. Feb 26, 2017 at 2:36 PM
    OleRomer
    OleRomer Professional Vagabond
    Brandon
    Utah/Wyoming
    04 Tacoma –- Ole Rømer
    ICON 2.5 Ext Travel C/O, Camburg UCAs, AllPro Expo Leaf Springs, ICON 2.0 RR Shocks, ARB/RAT/BAMF/CaptureColorado Armor, Dual Optimas Red/Yellow, 133w Solar System, Custom Bed Build, etc., etc.
    .190 aluminum. That's what I'm doing on both sides. Secure and you've got a surface to attach to!
  20. Feb 27, 2017 at 8:17 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I lost rear window glass in my camper (probably rock from a lawn mower). Camper mfg was out of business, and I did not want to spend time and money for repair. Ended up with tinted lexan cut by Tap Plastic. The good thing it is strong and rock proof. It can be scratched easy but easy to polish too. I use microfiber cloth and Plexus. They make the airplane windows out of it, so it must work on camper shell too.
