Broken Spring - 2017 TRD Pro
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PeteK, May 11, 2022.
  1. May 11, 2022 at 12:23 PM
    PeteK
    PeteK [OP] Well-Known Member
    Brockton, MA
    2017 Cement Truck
    Been doing some searching to no real avail. I've got a broken right-front spring on my 2017 TRD Pro. :(
    Got quoted $2,318 for parts and $840 in labor to redo the fronts. Total of $3,158. Apparently can't just get a spring?
    Does that sound like the going rate? Do I have any other options? I'm not looking for any lifts or anything fancy. I don't do any crazy offroading. Just a couple vacations a year that involve normal driving down some smooth-ish dirt roads. Also have to deal with the rubbish roads here in Mass.
  2. May 11, 2022 at 12:38 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    How did you break a coil? Any other damage to the shock, perch, etc?
    You have a couple simple options...
    1. Use this opportunity to upgrade to a new coilover. For example, Bilstein 5100's at the factory height
    2. Ask the TW community for OEM take-offs (cheap)
    3. Look on your local Craigslist, Facebook Marketplace, Offer Up, etc... for OEM take-offs (cheap)
    Absolutely DO NOT pay that ridiculous dealership quote!
    Good luck!
  3. May 11, 2022 at 12:39 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Sounds high to me, however is this a dealership who gave you the price?
    Taco_Craig likes this.
  4. May 11, 2022 at 12:40 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Go into this thread and see if anyone kept their factory coils and will sell them to you. There should be a TON of them available. Make sure the coils are the same (flat ground vs full diameter ends)
    https://www.tacomaworld.com/threads/taco-pro-owners-interested-in-a-spring-upgrade-for-front.643212/
  5. May 11, 2022 at 12:44 PM
    PeteK
    Brockton, MA
    2017 Cement Truck
    No clue. Just found part of it in the driveway the other day. Saw some other part of it in the street a few months back, but that was on trash day so thought it was just that and didn't put 2 and 2 together at the time.
    Yup.
    Thanks, I'll give that a try. "Flat Ground" I think is what I have where the lower coil goes from round at the bottom to a flat edge to sit on the shock. "Full diameter" I think I saw got introduced in 2020 where it is round all the way to the very end?
  6. May 11, 2022 at 12:45 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    100% correct!
  7. May 11, 2022 at 12:46 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    To answer your question, yes - that sounds like the going rate of a dealer job
    The even better news, yes - you have plentyyyy different options to explore.
    Name your price, and TW will get you whatever you want. If you want to spend 3k, we can get you some really nice replacement parts, 3x better than stock. If you don't want to spend a penny, I can guarantee someone around you locally has some stock take-offs they can't pay someone to come get, and would probably even help you install for some beer, steak, and a handshake.
    Edit: I need to read better, you have a PRO. You won't be finding free takeoffs, but we can still help you find some alternatives for a fraction of that quoted price.
  8. May 11, 2022 at 1:02 PM
    hokiehunter19
    hokiehunter19 Well-Known Member
    i have a pair of 2019 Pro Springs. Shoot me a message
  9. May 11, 2022 at 1:05 PM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Unfortunately, this is not uncommon with the flat ground TRD Pro springs. The regional rep for my dealer even attempted to blame driver abuse when we warrantied one on my father's Pro 4-Runner.
  10. May 11, 2022 at 1:08 PM
    suprafastcelica
    suprafastcelica TOYOTA 4 LIFE
    Tiffin, OH
    2017 Quicksand TRD Sport
    Outside: Custom Grille with FJ40 Grille emblem, TRD Pro Skid plate, TRD SEMA wheels with slightly oversized Pro Comp A/T tires, Scorpion Cat shield, Borla exhaust, Meso smoked mirror signals, SaBellCo tailgate lock, Body Armor Hiline front bumper, LED Headlights, LED fogs, LED taillights, Meso Total Tail stage 1 Inside: Meso dash inserts and door handle covers, URD short throw shifter with FJ TRD shift knob, Tinted front windows to match the rear,
    Can't you get the entire TRD Pro lift kit for that price?
  11. May 11, 2022 at 1:15 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    You can use that as an excuse to upgrade to the trd pro Eiback spring upgrade, or get the pair from @hokiehunter19. Definitely replace the springs your self and get an alignment, not even close to a 3k job.
  12. May 11, 2022 at 1:17 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    It would appear that is what they're trying to sell him. I would use my $ to upgrade at that point. This is the problem with non-serviceable items. Still annoyed they took the serviceable u-joints away!
  13. May 11, 2022 at 1:38 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
  14. May 11, 2022 at 1:38 PM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I mean, I know the guys spring broke, he not the first from the east coast to have had that problem, but I don’t think going from a 2.5 rebuildable shocks w/ tuned valving down to a 2.0 $100 throw away shock is an “upgrade.”
    TacoJova, danojeno and TireFire like this.
  15. May 11, 2022 at 1:47 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    Having had the TRD Pro suspension and having also ridden in a truck with 5100's, they're pretty darn comparable ride wise. Additionally, the Billies are adjustable, which is the biggest limitation of the Pro shocks. Lastly, calling the TRD Pro suspension "rebuildable" is a bit of a stretch. Yes, they "can" be rebuilt, but it's most likely more trouble than it's worth. I know there was a TW member offering rebuild services, but between the cost of the service, the shipping, and the modifications to the shock (adding a schrader valve), I think most people deemed it not worth it.
    I'm glad you like your Pro suspension, but it's not by any means the best option at factory ride height.
  16. May 11, 2022 at 4:19 PM
    dfanonymous
    ok, well I see where this is headed again… :rolleyes:
    Sure ok. Apparently people who want their cheap budget shocks to be “just as good as” are right. Apparently 5100s handle shock fade, and dampening in the same capacity as a 2.5… with that logic, the 6112 shouldn’t even exist. Because 5100s are “a upgrade.”
    It’s not about what I like, it’s the fact that you basically told the OP this. 5100s are not in the same playing field as any 2.5. Regardless of your bias.
    As far as the rebuild, I guess it just depends on the person. If you’re soo poor you can’t get it rebuilt, then you’re right, you shouldn’t be getting fox, kings or any other premium shock. Being a poor doesn’t mean that 5100s are a “upgrade.” It just means that you don’t want to do the maintenance.
  17. May 11, 2022 at 4:30 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    "where this is headed again"? Have we ever spoken to each other before? Seems to me, you might be dragging some baggage into this conversation.
    I did not tell OP anything about what shocks to get. I simply said, an example of a shock upgrade would be Bilstein 5100's. Bilstein 5100's are an upgrade over a broken Pro shock. In addition, the Bilsteins have some advantages that the Pro shocks don't. All OP was asking for was a OEM ride height shock that would work for mild off-roading.
    "5100's not in the same playing field as any 2.5"... Please indicate where I said that...
    I've had plenty of shock variations on my truck (OEM Bilsteins > TRD Pro > ADS 2.5 > King 2.5)... I can 100%, unequivocally tell you, the TRD Pro shocks are not that special. Would I replace a good Pro shock with a 5100... no. If I was on a budget, would I replace a broken Pro shock with a 5100... absolutely, yes.
    Also, are we ignoring that I provided the OP with not only a suggestion of where to get a replacement coil for his current shock, but also linked him to a source of numerous TW members that would sell/give him one?... I'm pretty sure I haven't lead OP astray in any fashion and you're making a mountain out of a mole hill.
    VaToy likes this.
  18. May 11, 2022 at 4:37 PM
    dfanonymous
    ok bud.
  19. May 11, 2022 at 4:48 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I assume that the coil itself can be purchased individually. If so, the minimum you could do would be to have the spring replaced. A reputable shop would do that for a couple maybe three hundred bucks, remove coilover, compress, disassemble, compress new spring, assemble, reinstall.
    If it were me I’d replace both springs given that the vehicle is 5 years old.
    End of story. Unless your Foxes themselves are in bad shape which is unlikely.
    Do not replace with 5100s.
    Also — you could do the labor yourself, but have a shop do the spring swap. It’s not bad at all to remove and reinstall a coilover.
    danojeno likes this.
  20. May 11, 2022 at 4:53 PM
    Iwilltaco
    Iwilltaco Well-Known Member
    @kairo’s guest house having a water with @not_nick
    Under development
    Parts.Toyota.com you can get new fronts and rears shipped during the sales they run for 2400. So I’d say no to their price. For that money you could get all new or change to a different setup.
