Broken spring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoma-toy, Apr 10, 2020.
  1. Apr 10, 2020 at 10:27 AM
    Tacoma-toy
    Tacoma-toy [OP] Master Auto/ASE Tech
    Danny
    Michigan
    2017 Tacom Pro cement
    rock lights, BFG's, Overhead console USB port
    Links?
  2. Apr 10, 2020 at 10:33 AM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
  3. Apr 10, 2020 at 11:27 AM
    Tacoma-toy
    Danny
    Michigan
    So far I cant get a hold of anyone because of everything going on. doesn't look promising to be able to get just a spring.
  4. Apr 10, 2020 at 11:29 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    You might just have to live with it for a little while till things go back to normal.
  5. Apr 10, 2020 at 12:03 PM
    Tacoma-toy
    Danny
    Michigan
    Me and my Wife have vacation planned for Utah at the end of July.....hopefully.... Stay safe!
  6. Apr 10, 2020 at 1:24 PM
    sigrooms
    sigrooms Well-Known Member
    Sam
    2017 MGM Tacoma TRD Off Road 4x4 Auto DCSB w/JBL
    I broke a small, replaceable, piece on my tonneau and was able to replace it easily for $~35 from my local Toyota dealership service department. A slightly poor example of the point you were getting at. ;)
  7. Apr 10, 2020 at 1:40 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  8. Apr 10, 2020 at 3:38 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Looking at the original pic of the spring .... It looks to be poorly designed. The coil diameter at the end(s?) is flat tapered to sit flat when installed. Reduction of the material at the required hardness caused a stress spot on the spring - which brakes.
    In short, I'd expect many failures with this design. Maybe they should have made a space flat on on side made to fit the spring pitch on the other - using a full diameter spring at the ends ...
    With that said, I'd push the Dealer/Toyota/NTSB? to push for a fix before a spring end spits off and blows a tire at highway speed ... JMO.
  9. Apr 10, 2020 at 4:19 PM
    5nahalf
    Erik
    Minnesota
    They changed it for 2020
  10. Apr 10, 2020 at 4:21 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    It appears to be a closed-end/flat-ground coil.
    I agree; the geometry doesn't look right.
    To me, it looks like the last coil needs more taper and more ground off to have it seat properly.
    If they're double forging to form the flats, that can soften the material.
    As far as I know, Eibach grinds their flats.
  11. Apr 10, 2020 at 4:42 PM
    DR TACO
    DR TACO Well-Known Member
    Denny
    Fort Mohave
    2019 Tacoma Off Road 4x4 Double Cab
    Pro grille, POD lights, SEMA wheels.
    5nahalf[QUOTED] likes this.
  12. Apr 10, 2020 at 5:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Closing the last coil and grinding it flat is standard practice for coilovers. However, if there's a deviation in flatness or parallelism, the coil is put in bending and can break. Happened with one of my Icons in my previous truck (this was before Icon switched to Eibach springs). Happened to @Ellswj86's Kings last month: https://www.tacomaworld.com/threads/broken-king-coilover-spring.654792/page-3#post-22888055
  13. Apr 10, 2020 at 5:58 PM
    Canufixit
    New England
    Perfect !!
    Tacoma-toy[OP] likes this.
  14. Apr 10, 2020 at 6:18 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    bullshit. Just like the Fox on the raptor, Fox will rebuild them for you. So obviously there are spare parts. Parts are interchangeable with all their other shocks, and shocks are completely rebuildable, they will probably even sell you a rebuild kit. As for warranty, that’s Toyota’s issue not Fox’s.
  15. Apr 11, 2020 at 3:38 AM
    #35
    Tacoma-toy
    Danny
    Michigan
    I'm sure that's true for the shock but i not so sure about the springs??? I tried to fill out a service form with fox but there is no options for the springs. I sent the an email but until all this crap settles down I don't expect to hear form anyone for awhile.
  16. Apr 11, 2020 at 7:36 AM
    #36
    mutely
    I don't know if the spring is sourced from Fox. Fox don't make springs, and Toyota has more "clout" with vendors than Fox (ie spring manufactures), so I'd be surprised if it was sourced from Fox. I seem to remember someone mentioned (maybe in the 'Taco PRO owners - spring upgrade' thread) that Eibach made the OEM springs for Toyota / Fox setup. But I've never confirmed that, and there is so much miss-information posted about suspension on this forum that I'd take that with a grain of salt.
  17. Apr 11, 2020 at 7:41 AM
    #37
    Tacoma-toy
    Danny
    Michigan
    Thanks, I have a email out to Eibach just waiting to hear back.
  18. Apr 14, 2020 at 7:11 PM
    #38
    zano
    zano Well-Known Member
    south chicago burbs
    2011 TX Bro
    2.25" lift, SPC UCA, Dobinson's C59-314 coils & 500lb leaf packs, Billy 5100's & 5125, Tom Woods 1pc ds, TRD exhaust, OEM black tube steps, Konig Countersteer (FN) wheels, Michelin LTX/AT2's
    My Eibachs were ridden hard and put away wet...and broken in several spots...
  19. Apr 14, 2020 at 8:58 PM
    #39
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    :eek::puke:
  20. Apr 14, 2020 at 9:08 PM
    #40
    therealprotaco
    therealprotaco Always Skeptical
    Gilbert, AZ
    2021 Lunar Rock Tundra TRD PRO DC
    That was @Ryan at Eibach posting about being the OE supplier for the pro springs:
