Broken spring
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tyepel, Apr 14, 2023.
  1. Apr 15, 2023 at 2:34 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    If I had a oem fox coilover take-off, I'd give it to you, but I only have standard oe tacoma coils in the scrap bin.
    I have some king coils in stock, but they are probably too heavy. I could order in some coils for you. Probably 550 or 600lb. I'm not sure what those coils length or rate are if I'm honest.
    Otherwise we have upgraded suspension on the shelf if that's helpful.
    Steves104x4 and Ricardo13x like this.
  2. Apr 15, 2023 at 2:41 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    #trailboss coming in clutch!
  3. Apr 15, 2023 at 3:27 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    Fox uses Swift coil springs. Figure out the ID, spring length, and compression ratio.
  4. Apr 16, 2023 at 10:30 AM
    tyepel
    tyepel [OP] Well-Known Member
    British Columbia
    2017ProAT
    33s, HC rear bumper, Sliders, Skids, Dual battery, fridge
    Thanks for the info. Currently trying to decide between ordering the eibach lift springs with a 1inch block in the rear or upgrade to elka 2.5 remotes. Long term I was planning to upgrade to the elkas but there's nothing really wrong with the fox's.
  5. Apr 16, 2023 at 10:32 AM
    tyepel
    British Columbia
    2017ProAT
    Thanks, it's one of the options I've been considering.
    Chew[QUOTED] likes this.
  6. Apr 16, 2023 at 12:28 PM
    Ballz
    Bfe SF Bay
    If you’re considering Elka, you ought to look into Bilstein 8112’s and 8100’s for the rear. They don’t need to be rebuilt as often as Elka, King, Fox, or most other coilovers as long as you’re not pouncing on em’. To go the full 3” just need the Ekstrom 1/2” spacer on the drivers side (for the taco lean) and 1/4” spacer on the passenger side. The bilsteins run super plush off road for crawls, fast washboards, what ever you throw at them. Plush over bumps, potholes, yet thru their valving ride firmer around the curves on mountain roads.
    Superdave1.0 likes this.
  7. Apr 16, 2023 at 6:05 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    There is a set of Fox pro springs takeoffs in B/S/T right now.
    Chew likes this.
  8. Apr 16, 2023 at 6:41 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    I believe I read that Eibach makes these springs for Fox. I would see if Eibach could help you.
    Chew likes this.
