Broken Sun Visor- Need New One Cheap!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dinosaura85, Aug 15, 2011.
  1. Aug 15, 2011 at 10:09 PM
    dinosaura85
    dinosaura85 [OP] New Member
    Rosa
    SFV, California
    Toyota Tacoma
    Hello everybody! First of all, I am a new member, but long time lurker. This site seems to be a great site, so I finally decided to join.
    As for my question, I noticed a lot of people have had trouble with their 2nd Gen. Sun visors. The driver side visor of my '06 Tacoma started to droop about a year ago. I couldn't push it all the way up. My bf took it off and fixed the little hinge on it, but a couple of months later, it was drooping again. I think it's beyond repair, so I was wondering if anybody has bought a new one, cheap from an online store. I've checked ebay but they don't have what I need. Oh, and I no longer have warranty so having the dealership change it is not an option.
    I realize there are probably a few threads that talk about sun visors already, so I am sorry if I am being repetative.
    Thanks!:)
    - Rosa
  2. Aug 29, 2011 at 12:18 AM
    gozar
    gozar Well-Known Member
    Arizona
    2010 TRD Off-Road 4x4
    :: bump :: (I need one too.)
  3. Aug 29, 2011 at 11:21 AM
    gozar
    Arizona
    double bump
  4. Sep 1, 2011 at 10:19 PM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Mine just broke also :(
  5. Sep 7, 2011 at 5:40 AM
    dinosaura85
    Rosa
    SFV, California
    Toyota Tacoma
    @Gozar, I like your picture. Thats the exact same view I have of the sun every day. Sunglasses help for the most part, but still trying to find a visor replacement
  6. Oct 7, 2011 at 2:10 PM
    snicklefritz
    snicklefritz Member
    '10 bare bones
    looks like this site has it
  7. Oct 8, 2011 at 12:01 AM
    JoMo's Taco
    JoMo's Taco Member
    Joey
    La Quinta
    06 Prerunner Dlb Cab
    Camburg 4" Spindles, OME Front Shocks and Coils, All Pro Runner Rear Shocks, 3" Block, GrillCraft grill, Pioneer Deck, Custom Tacoma Bed Mat, Dash Lights, Razo 11.8" Rear View Mirror, 5% Rear Tint, Wet Okole Seat Covers, Devil Horns Emblem...
    Wow your first post and it was just what I needed!!! Thank you so much!! :D
  8. Oct 10, 2011 at 10:37 AM
    snicklefritz
    snicklefritz Member
    '10 bare bones
    kewl...glad I could help.
  9. Mar 9, 2013 at 12:02 PM
    B.Snow
    B.Snow New Member
    Arizona
    Silver 07 Sport Double Cab 6' bed
    Rubberside down front bar, fog lights, Undercover taneau cover, side step bars.
    Remove the visor from the truck. With a VERY sharp knife slit the edge of the fabric at the point where the rod enters into the visor. Carefully peel back the fabric exposing the plastic body of the visor about 1 1/4". Cut a small slit in the plastic body of the visor in the same location on both sides. The slit should not be any longer than 3/8". Take a threaded radiator hose clamp approx. 1 1/2"-2" dia. and insert it through the slits in the visor and tighten it. Fold fabric over clamp. Obviously the clamp screw will be a visible bulge but the visual impact will be minimul when the visor is re-installed. The other advantage is that if the visor ever becomes loose again all that has to be done is tighten the clamp.
  10. Jun 24, 2013 at 10:43 PM
    NewMexiTaco
    NewMexiTaco Abron Cabron
    Abraham
    Santa Fe, NM
    2007 4x4 DC LB TRD Sport
    Weathertech mats; Wet Okole seat covers; Kobalt Lowpro truck box,(sitting in the shed) Snugtop Hi-liner camper shell; AFE Pro Dry air filter, Tailgate Hoseclamp mod; 5100s all around, Light Racing UCAs, OME 885 coils, OME Dakar Leafs, CB Drop, Driveline spacer. Epoxy Satoshi; Redline Hood Struts. 4x Mil Spec. bed D rings; Brute Force Fab custom DCLB Hybrid Sliders, ARB w/ Warn M8000 wench, Diff Breather mod, Alpine Deck w/ ipod cable. Iphone ziptie to rearview mirror 4wd-cam mod!
    Stupid Visor is broken. little search function, and>>>>>>
    Awesome. this d.i.y. is exactly what i am looking for. Tacomaworld FTW.and hose clamps is wrenching i can do too...lol
  11. Jun 24, 2013 at 10:53 PM
    tensecondchevelle
    tensecondchevelle Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
    Ill have to give this a try.... The way I fixed it was pretty ghetto, I can't even use my visor haha
  12. Sep 25, 2013 at 12:48 PM
    Chagge3
    Chagge3 New Member
    06 Tacoma
    Used twine to hold it together until I can get a clamp. Saved me some bucks. Thank you!
  13. Sep 25, 2013 at 1:26 PM
    tensecondchevelle
    Eric
    Mesa Arizona
    Looks like you're going West on the 202 about 1/4 mile away from the Scottsdale Rd exit?
    A-Mountain on the left (ASU)
  14. Sep 25, 2013 at 2:10 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Auto wrecker?
  15. Nov 25, 2013 at 4:02 PM
    NicP
    NicP Well-Known Member
    Nic
    colorado
    05 DC LB
    3" Icon CO Icon Rez and AAL ProComp 7089 BFG 285 AT KO
    rep for B.Snow
    Additional ideas suggestions
    1-use dremel tool to make the slots
    2-cut closer to the cylinder than the center of the visor. there is a metal flange on the shaft within the body of the visor and you can hit it and it will obstruct the screw clamp.
    3- I did the mod with screw clamp, but I think you could use zip ties for lower profile. I think the metal zipties would work the best. You can grab the end with a pair of needle nose pliers and spin it like an old style key for sardines or spam befor they had pull tabs. You would be able to get enough tension on them this way
    4- be aware of location and orientation of the screw clamp. it can obstruct the visor and dig into the ceiling.
    The Stealership wanted $62 for this item. supposedly they have fixed the problem , but even though it hinders safe driving it is not a recall item.
  16. Jun 23, 2014 at 5:33 PM
    xgalvanxgx
    xgalvanxgx seymour butts
    Gerardo
    OC (Lake Forest) California
    TRD Off-Road BlackSandPearl 07 PreRunner
    DTF Race Kit with 2.5 x 10 Kings, DMZ SUA rear with 16" triple bypass Kings, King bumpstops front and rear, 17" KMC RG1 powdered in Matte Bronze with black ring with 37" BFG KO2s, front and rear DTF bumpers, front Fiberwerx glass and Mcneil trophy bedsides, K&N 77 Series Intake, Magnaflow, Pioneer touchscreen, Rockford Fosgate 10" sub with box and amp. Dyanamat walls, Andres' devil horn emblem, 50" D4 curved LED bar, rear chase light rack (brake, ambers, white lights) Engine brace, deleted inner wheel wells for max up travel. Cab roll rage built into bedcage.
    woo just tried this works like new again. thanks b. snow!
  17. Jun 23, 2014 at 6:00 PM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    Good luck! These trucks are very hard to find in a wrecking yard...
  18. Jul 23, 2014 at 7:01 PM
    TacomaPaul
    TacomaPaul New Member
    2006 Tacoma
    Thank you B.Snow for posting this fix for a broken visor. It sure worked for me and saved me about $100. Gotta love that! I really appreciate it.
  19. Jul 24, 2014 at 9:12 AM
    tensecondchevelle
    Eric
    Mesa Arizona
    sub'd because I accidently just un-subscribed to this thread and still need to do this!
  20. Aug 5, 2014 at 9:14 AM
    mike s
    mike s Well-Known Member
    South Carolina
    2019 TRD OR
    I just did this, it worked great. I used an 1/8th inch drill bit to make the slots, drilled all the way thru the plastic after cutting the cloth back. I used two small hose clamps just like in the picture, and then pulled the cloth back over to kind of hide the repair.
    thanks!!
