Broken tabs on Fender Flare!!! In need of a cheap fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by raskal311, Mar 15, 2010.
  1. Mar 15, 2010 at 4:33 PM
    raskal311
    raskal311 [OP] Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    I was in Mammoth this past weekend snowboarding with the lady. While in the parking lot I noticed some ice had formed on the fender flare. So I thought I'd get it off by giving the fender a light jab. Well, I guess the tabs that were holding the flares to the truck were frozen and were brittle. Three or four of the tabs that holds the flare to the truck broke off!!!!
    Anyway, what’s the best way of repairing the flare? I was thinking about using fiberglass and fiber glassing it back on. I’m also considering bondo since it’s easier to work with. Does anyone have a better idea?
  2. Mar 15, 2010 at 4:37 PM
    Rocktaco
    Rocktaco Member
    Rockford, Illinois
    09 TRD OR DC pyrite Mica
    Bakflip G2, Dynolock, Lamin X, weather techs
    Ive used plastic two-part epoxy in the past and been very successful.
  3. Mar 15, 2010 at 4:54 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    is the fender flare broke or the clips that hold it on?
  4. Mar 15, 2010 at 4:57 PM
    raskal311
    S. Cal
    The clips, the two part sounds like a great idea.
  5. Mar 15, 2010 at 5:31 PM
    TacoSupreem
    Hayden
    Kentucky
    Here you go,
  6. Mar 15, 2010 at 5:32 PM
    TacoSupreem
    Hayden
    Kentucky
    Or was it these?
  7. Mar 15, 2010 at 5:42 PM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    silicone?
  8. Mar 15, 2010 at 8:30 PM
    raskal311
    S. Cal
    No, the plastic part that those clips attaches to are broken.
  9. Mar 15, 2010 at 8:31 PM
    raskal311
    S. Cal
    :S no way silicone will work.
  10. Mar 15, 2010 at 8:43 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Plastic weld them back on
  11. Mar 24, 2010 at 10:47 AM
    raskal311
    S. Cal
    wow, toyota wants $2.80 for each clip....
  12. Mar 24, 2010 at 1:23 PM
    TacoSupreem
    Hayden
    Kentucky
    Check eBay man. I think I've seen em on there for pretty cheap. But if you just need a couple then the dealer is probably the easiest.
  13. Mar 24, 2010 at 1:56 PM
    physedfailure
    physedfailure Active Member
    Jersey Shore
    07 TRD V6 BLACK
    Trimmed flaps air compressor w/ air horn yellow fogs lund grille rear leaf TSB Billy's 5100 all around set at 2.5" in front BHLM fogs on anytime aux reverse lights TRD seat covers westin side steps (for wife) oil drain valve/ K+N oil filter
