Broken Wheel Stud, Need Help ASAP
Discussion in 'Wheels & Tires' started by BAP_29, May 24, 2011.
  1. May 24, 2011 at 12:38 PM
    BAP_29
    BAP_29 [OP] Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    To avoid explaining how I broke the wheel stud, Im just gonna get to the point. On the front driver side wheel hub, one of the studs broke in half. I know you can get a replacement stud, but is this a simple job I can do on my own or would I need to take it to a shop for repair? Any info about this repair would be greatly appreciated.
  2. May 24, 2011 at 12:45 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    they can be pressed out/pressed in, IIRC. I had one break on mine and since I was already buying a stud, I had them replace it too.
  3. May 24, 2011 at 12:47 PM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    i've taken the rotor off before and beat one out with a hammer then replaced the new one by finding a nut the same diameter and tourqing it down with an impact.
  4. May 24, 2011 at 12:56 PM
    BAP_29
    Ben
    North Carolina
    Will I have to remove the rotor and caliper and bleed the brakes?
  5. May 24, 2011 at 1:03 PM
    98tacoma27
    Ben
    Not Beech Creek
  6. May 24, 2011 at 1:06 PM
    BAP_29
    Ben
    North Carolina
    I think I have a general idea of what to do now. I appreciate the help guys. Now does anybody know where to get a wheel stud besides ordering from the dealership?
  7. May 24, 2011 at 1:09 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Any autopart stores should keep a couple in stock. Just call around until you find one.
  8. May 24, 2011 at 1:11 PM
    DonnoD
    DonnoD Well-Known Member
    don
    las vegas
    07 dc 4x4 v6
    oreilly's, pepboys, autozone, checkers they all have em. i bought some from oreillys for $3 a piece
  9. May 24, 2011 at 1:49 PM
    BAP_29
    Ben
    North Carolina
    I just picked up 2 from advance auto for 2 bucks a piece. I think I may try to replace all 6 depending how easy the first one is to replace.
  10. May 24, 2011 at 2:20 PM
    Southern01Taco
    Sean
    Holden, La
    If you are thinking about doing all 6 then I would go ahead and buy them all. So that you don't have to tear your truck down twice. If you decide not to change them, then you will have spares for the future.
  11. May 24, 2011 at 3:14 PM
    BAP_29
    Ben
    North Carolina
    Yeah Im gonna pick some more up tomorrw. Advance only had 2 in stock. But now I gotta figure out how to break the two bolts loose that are holding the caliper to the hub. its gonna be a pain in the butt im sure.
  12. May 24, 2011 at 3:21 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  13. May 24, 2011 at 5:48 PM
    BAP_29
    Ben
    North Carolina
    Just to get this straight, there's no possible way to get the studs out without removing the caliper correct?
  14. May 24, 2011 at 6:05 PM
    BAP_29
    Ben
    North Carolina
    Ive sprayed PB Blaster on the 2 caliper bolts and I've got nothing so far using my socket wrench.
  15. May 24, 2011 at 6:10 PM
    tommyc
    tommyc Well-Known Member
    tommy
    4X4 SR5, TRD
    Dude don't make it a hard thing, you can do it in your yard, get new stud and nut a big hammer and remove the wheel. put the nut on the end of the thread smack it with the bah (big ass hammer) once it pops out remove the nut.
    put the new stud in and drive it into place with the nut. that's it. now if it's the rear your screwed you have to remove the axel. good luck dude
  16. May 24, 2011 at 6:14 PM
    BAP_29
    Ben
    North Carolina
    Ive never taken the calipers off so I'm not suprised I'm having trouble breaking them free. The entire brake assembly looks like a mess it has so much rust on it.
  17. May 24, 2011 at 6:58 PM
    BAP_29
    Ben
    North Carolina
    Got the Caliper off! Now its on to the rotor. Lemme know if this is right.
    Spray PB Blaster on the outside edge here the hub and rotor meet
    Now where on the rotor do i hit it with a rubber hammer?
  18. May 24, 2011 at 7:04 PM
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    with a rubber hammer anywhere or try to hit it out, with a ball peen hammer hit it on the hub face just dont hit the studs.
  19. May 24, 2011 at 7:06 PM
    BAP_29
    Ben
    North Carolina
    Would hitting it behind the rotor where the caliper used to sit be a good place? I just dont want to damage the rotor thats why im asking so many questions haha.
  20. May 24, 2011 at 7:09 PM
    DonnoD
    don
    las vegas
    07 dc 4x4 v6
    if youre hitting it with a rubber hammer then no you wont damage the rotor. yea just hit it from the back
