Broken Wheel Stud
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Armkb, Aug 15, 2009.
  1. Aug 15, 2009 at 5:37 PM
    Armkb
    Armkb [OP] Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, Toytec AAL, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Toyota Wheel Locks, Extang Trifecta Cover, Fumoto Drain
    In all my years of auto repair never broke a wheel stud...until today. Years ago I bought a good Craftsman Digitorque wrench(not a beam type but adjustable) just for this purpose and never ran into trouble till this afternoon. Was changing my oil and rotating the tires for the 10k service. Hand tightened the nuts first...then ran them up to about 35-40 ft lbs then went to do a final torque of 85 ft lbs when I noticed a few of the nuts just kept turning. Wasnt putting a hell of a lot of effort into it. So I loosened the nuts and tried again. This time one stud snapped before I acheived the proper torque value.
    Has any body else had the same problem? Does Toyota use cheap studs, is it common with the 2nd gen...or I should I be looking at a new torque wrench. Also whats involved in replcing the wheeel stud? Does the hub need to be removed or can it be done with the hub on the vehicle?
  2. Aug 15, 2009 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You can replace the stud with the hub on the truck. Just knock the old one out, insert the new one, and use a lug nut to pull it through.
    scottalot likes this.
  3. Aug 15, 2009 at 6:43 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    Just yank the caliper off, rotate the hub so the stud you want to remove is where the caliper was (so it has clearance to come out) then hammer it out.
  4. Aug 15, 2009 at 7:22 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    10k miles on an 09 and the studs are breaking? Wow! I would contact the dealer also.
  5. Aug 16, 2009 at 7:04 AM
    coma09
    coma09 Senior Member. Hey, what's That supposed to mean?
    BC Canada
    2013 taco access cab 4x4
    Putco led map light bulbs, bed mat, Xiang trifecta tonneau, blackout front emblem, paint tow hoop, led bed light strip, scan gauge II, debadge, buff paint, oem fog light kit, 1000w inverter, Viair 300P compressor, Contura V dash switches, chop last L bend from exhaust, remove charcoal air filter, extinguisher, mag light, Ss side steps, kayak rack, tailgate security, bed mat security
    Only had this happen when one time I thought to grease the studs. Bad move.
    Re hammering them out - NO! you can damage the wheel bearing from the shock, or damage the hub. We have a cheapie tool store here - Princess Auto. You can get a stud press for about $10. This is like a small heavy duty c-clamp with a split end so the stud can go past it.
    Pulling the stud in - use a wheel nut, and preferably a few heavy washers to take up some of the bolt slack,and spread the force across the washer, vs against the hub.
    Otherwise, what you are doing is dead on.
  6. Aug 16, 2009 at 7:19 AM
    ozmon420
    ozmon420 Well-Known Member
    miami, florida
    08 tacoma
    18x9 pro comp 7031 rims, alpine iva-d310 w/sirius sat radio, ipod connection, tv tuner, reverse camera, bug deflector, wet okole seat covers, tinted windows, running boards, toytec coilovers front set at 2.5'' , AAL rear,5100's rear, TC UCA, leer topper, bruteforce rear bumper, ARB rear locker.
  7. Aug 17, 2009 at 4:03 PM
    Armkb
    09 TRD Sport DCLB
    Ill look into the tool you are talking about. Looks to be an easy job. Thanks all for your replies.
  8. Aug 17, 2009 at 6:01 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    On my old honda accord the dealership cross threaded my aftermarket wheel locks and lug nuts. They ended up breaking off 3 lugs trying to get the wheel off. They used heat and a gentle tap of a hammer and they came right out...
  9. Aug 17, 2009 at 6:13 PM
    otter
    Rob
    MI
    09 4 cyl Reg Cab
    If you're damaging the wheel bearing when hammering out wheel studs then you're hitting way too hard. It doesn't take much force to dislodge them.
  10. Apr 30, 2016 at 3:20 PM
    Themud
    Themud Member
    Jud
    2010 taco 2.5 toytec ecgs bushing leather
    Toytec level Ecgs bushing Leather seats
    I broke a stud on the front left after ecgs install. I cannot figure out how to get a new one in.
  11. Apr 30, 2016 at 3:59 PM
    Clearwater Bill
    Clearwater Bill Retire from work, but not from life.
    Billy
    Clearwater Florida
    '13 5 lug base ACLB w/convenience package
    7 yo thread revival. Congrats.
    Have you got the old one out?
    Get the new one started, a touch of lube on the splines. If you can tap from behind that will get it going.
    Put a lug nut on it and pull it through. If the threads don't go deep enough to get it all the way in, put a spacer over part of it, a close fitting thick washer, the lug nut back on and finish it off.
  12. May 1, 2016 at 6:38 PM
    Themud
    Themud Member
    Jud
    It is the front. I cant see the back where there is one. It looks like it needs to be drilled and tapped.
  13. May 1, 2016 at 7:42 PM
    Clearwater Bill
    Billy
    Clearwater Florida
    So you don't have the old stud out nor a new stud in hand, correct?
    If you look at one here you'll see the spline part is what creates the press fit. Drill and tap will ruin things. Only tapping that should be happening is with a hammer.
    Pull off the caliper and rotor. Rotate the hub until the backside of the offending stud is clear, and drive it out with a large punch and hammer. Doesn't take excess pounding.
    Or you can take it to a pro. It's ok to drive it with the remaining lugs holding the wheel.
  14. May 1, 2016 at 7:45 PM
    rogs6266
    rogs6266 Well-Known Member
    Alliance, OHIO
    '13 TRD Sport 4X4 DCLB MGM
    SOS weld on sliders, SOS bed rack, SOS front aluminum winch bumper with center and head light hoops, Stealth 6 wheels wrapped in goodyear duratracs, 285-70/17 Beer opener in bed, Thule roof rack on factory rack, Tool box, bed mat, K&N cai, flowmaster side out duals, and tailgate extender, Fog light anytime mod, no mud flaps mod Weathertech full set, Wet okoles front and rears, full OME 886 suspension lift with Dakars in rear, smittybilt X20 comp 10 winch, factor 55 yellow pro link,
  15. May 1, 2016 at 8:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    id reaplace all the studs that you felt you kept spining.
    Also goes without saying get a new torque wrench... its likely you left it adjusted to a certain ftlbs and that messed the spring up, always undo them all the way.
  16. May 2, 2016 at 8:48 AM
    Themud
    Themud Member
    Jud
    The dust pan thing looks like it's in the way. I pulled the calipers off and hung with a bungee cord. Looking where that was I cannot see where there are any stud ends. I looks like they are part of the drum.
  17. May 2, 2016 at 3:19 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
