Broken Windshield Wiper Control.
Discussion in '4 Cylinder' started by Dan0331, Mar 2, 2014.
  1. Mar 2, 2014 at 6:34 AM
    Dan0331
    Dan0331 [OP] Member
    Dan
    Milwaukee
    Regular cab
    Just bought my first Tacoma yesterday. Great little truck and cant wait to do some mods and customize it. But on the way home from the dealer I tried to get the salt off my windshield and the the washer fluid wouldnt work. its not like it just ran out of fluid, because even the wipers wont work when I try. Has this happened to anyone before? I already called the dealer and they are gonna fix it, just wondering if this is common. Thanks
  2. Mar 2, 2014 at 10:38 AM
    nettto
    nettto Active Member
    San Diego
    2013 Tacoma 2.7l
  3. Mar 2, 2014 at 11:18 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I've been on here a while and don't think this is a common issue. But X2 on getting the intermittent control if you can.
  4. Mar 2, 2014 at 2:40 PM
    ecoterragaia
    ecoterragaia Well-Known Member
    Virginia
    '06 RC, 4X4, 5 speed
    Did you check the fluid? My wipers dont come on automatically with the fluid pump activation, I usually have to pump fluid then activate the wipers manually right after.
  5. Mar 3, 2014 at 4:45 PM
    Dan0331
    Dan0331 [OP] Member
    Dan
    Milwaukee
    Regular cab
    The fluid is full and doesnt spray out at all. The windshield wipers work if I turn them on. Just when i try and use the washer control nothing happens. Maybe the motor is fried???IDK
  6. Mar 6, 2014 at 8:42 PM
    MikeCB600F
    MikeCB600F Poverty Truck
    Plainfield, IL.
    2012 Reg Cab 2.7L 4x4
    Extang Trifecta Tonneau cover
    Sounds like you have the NON intermittent wipers. You activate the washer and then have to turn on the wiper. New intermittent wipers usually run $110 - $120 and can be installed in about 15 minutes. Check the classified section, you may find one a little cheaper.
  7. Mar 7, 2014 at 4:37 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Yeah, I'd lean towards fried washer fluid motor. But who knows, it could be the stalk.
  8. Mar 7, 2014 at 4:52 AM
    muddedtaco
    muddedtaco Well-Known Member
    Wesley
    South Mississippi
    96 Tacoma 4x4 2.7
    Rattle caned black, Mossy oak door panels, shifter shroud, and radio cluster surround
    My switch went out on my 96, when I started the truck the wipers started and would not turn off, I had to pull the fuse to make them stop. I replaced it my self put it waas a pain in the rearend, had to pull the steering wheel air bag module and then I drive all the little conectors out with a little screwdriver.
  9. Mar 8, 2014 at 2:05 PM
    Dan0331
    Dan0331 [OP] Member
    Dan
    Milwaukee
    Regular cab
    Thanks for the input. It just randomly started working again. When I take it to the dealer Ill have them check it out, but overall its fine. Might have been the subzero temps we been having here in Wisconsin.
  10. Mar 8, 2014 at 3:13 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Kenwood CD, MTX/Jensen amps, Rockford/Polk speakers.
    That is my best on the problem, I go through the same thing here in New England.
    Try this: Next time it happens, see if you hear the motor whirring. It will try to pump even if something is frozen up.
  11. Mar 8, 2014 at 5:59 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Sounds to me like the previous owner had summer fluid in there, or at least proportionally not very much of the winter type, and it just froze up
    The base model wiper stalks don't turn the wipers on with the spray. I kinda liked that because you can get a good soaking before wiping it off.
  12. Mar 8, 2014 at 7:08 PM
    Dan0331
    Dan0331 [OP] Member
    Dan
    Milwaukee
    Regular cab
    Yea the fluid seemed pretty watered down from the dealership. I siphoned the rest out and put in just regular fluid, temps are rising around here so it should be good. In the 40s and 50s next week. After the winter we just had it will feel like July. haha
