Broken "Wings" inside oil pan
Discussion in '4 Cylinder' started by vitaman, Jan 19, 2012.
  1. Jan 19, 2012 at 2:47 PM
    vitaman
    vitaman [OP] New Member
    09 tacoma TRD
    :eek: I have a 2000 4 cyl motor that had a rubber expanding oil plug. The wings broke off inside the oil pan,(from overtightening I suppose). A mechanic I called said he see's foreign objects in pans all the time, and it is nothing to worry about because the oil pump has a screen. Is there any danger of these pieces damaging the motor?
  2. Jan 19, 2012 at 2:48 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    No. Try placing a magnet on the pan. It will help keep it in one spot. But it shouldn't move much.
  3. Jan 21, 2012 at 6:37 AM
    vitaman
    09 tacoma TRD
    Good Idea. Found some small powerful magnets that should work fine.
  4. Feb 8, 2012 at 1:55 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    It would be pretty easy to pull off the pan, clean it, and reassemble.
