Broken wire close to plug in wiring harness, how do I fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Poolstick, May 24, 2013.
  1. May 24, 2013 at 6:05 AM
    Poolstick
    Poolstick [OP] Well-Known Member
    So yesterday when I was trying to drill a hole to add a switch below my 4wd knob, I managed to catch the wires coming out of the back of the knob with the drill, which ended up breaking one about 1in from the white plug that connects to the 4wd switch. Its a big plug, with about 5 terminals, but only 3 wires going into it (black/white, grey, and blue). Because I have only an inch to work with, I'm a little nervous about stripping it and using a crimp connector. Is there any way to get the little bit of wire out and attach the existing wire (which has plenty of slack) directly into the plug? I've also considered soldering them together, but I tend to make a mess of it and since I don't have a lot of wire to work with, that makes me a little nervous as well. Also those wires are so tiny, is there a trick to working with them?
    Search didn't turn up much, but maybe I'm not using the correct terminology. If anyone needs more info or pics, let me know.
  2. May 24, 2013 at 6:39 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Without seeing the wire and not really knowing how it connects inside the switch my only advice at this time would be to solder and then use shrink wrap over the wire. That way you know you still have a good connection. Like you said, I wouldn't use a crimp connector especially if the wires are that small. You want something that will last and you know will stay together and with solder you'll get that.
    Sorry I can't give you any better advice but without a picture of the connector that's all I got.
    Hope you get it fixed. I hate it when I do stuff like that.
  3. May 24, 2013 at 7:40 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    get a replacement terminal and pop out the cut one
    (depending on the connector, you insert a tool and the plugs
    come right out of it) and crimp on the terminal on the other
    end of the cut wire and jam it back in. or just get a splice and
    solder the two back together and use heat-shrink around it
    pretty simple really the only roadblock is identifying the terminal type
    digikey will have the parts you need, this is just a small sample
    http://www.digikey.com/product-sear...-disconnect-connectors/1442842/page/2?k=blade
  4. May 24, 2013 at 4:55 PM
    Poolstick
    Thanks for the tip. I ended up going with solder + shrink wrap. Seems to be working for now.
