Broken Zerks Fitting On Rear Leaf Shackle
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95Yota4x4, Dec 23, 2011.
  1. Dec 23, 2011 at 2:43 AM
    95Yota4x4
    95Yota4x4 [OP] -FURY FROM THE SKY
    J.D.
    Houston, Tx
    Black 95 Tacoma, reg cab, 2.7L 4 cyl, 4x4
    4" lift
    I was greasing the zerks on my driver side rear leaf shackle & couldn't remove the grease gun from the fitting. Tried everything & still couldn't get it. After about 20 minutes of finess i decided that the only way it was coming off was gonna be brute strength. I was right; however the damn Zerk came off with it. :mad: now i need to replace it. any write ups on this issue? if not please advise.
  2. Dec 23, 2011 at 3:57 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Depends on the zerk.....it could be a screw-in or a push-in type.
    I've seen this happen a lot at work...and in most cases, they break after the zerk head. It leaves a small metal donut in the hole.
    But since you can't really tell what type it is..... get a small EASY-OUT Screw extractor. Small enough that it'll sink in that hole atleast 1/8" or more. This should be able to remove both types - use an 'unscrewing' motion to pull it out.
    When you remove the piece, take a look at it. Does it have threads on it?
    This will tell you what type (threaded or press-in) to buy.
    Good Luck
  3. Dec 23, 2011 at 7:38 AM
    95Yota4x4
    J.D.
    Houston, Tx
    4" lift
    Thanx. Just bought an easy out tool. Gonna take care of it right away. Man that's been bothering me since it happened.
  4. Dec 23, 2011 at 1:02 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I broke one off my OME shackles and it left part inside the threaded hole. It wasnt seized in there so it came out easily. Then I just went to the local parts store and matched one up. Wasnt a big deal, cost like 10 cents for a new zerk.
    Most grease guns can be adjusted for different sized zerks by twisting the end. Sounds like yours is just a bit too tight.
