BrokenTusks 2013 Scion tC Release Series 8.0 Build
Discussion in 'Other Builds' started by BrokenTusk, Apr 21, 2013.
  1. May 2, 2013 at 9:30 AM
    #161
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Dezod has made some MEAN tC's. Look up Jessica's tC on YouTube. Bitchin'!
  2. May 2, 2013 at 9:35 AM
    #162
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Right from agency power themselves. Cheapest I found it @ $140.
    I know, been pouring over youtube videos of tC's, they are some sexy cars when done up right.
  3. May 2, 2013 at 9:39 AM
    #163
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Let me know if you feel any difference with it once its installed.
    They definitely look really nice when done up right. Lots of nice ones out there on youtube
  4. May 2, 2013 at 10:57 AM
    #164
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Will do, I've heard good things.
    I'm not sure if theres anything else I want to do to the body of the car. I kinda like it how it is.
  5. May 2, 2013 at 11:05 AM
    #165
    tacobell007
    Drew
    Western MA
    I heard the motor revs quicker... I know I am going light weight flywheel my clutch craps out. Not sure on your inspection laws but maybe tinted tails? Could always swap LED lights for halogens, did that with my plate lights.
  6. May 2, 2013 at 11:14 AM
    #166
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Going to do a bunch of research on this issue, see if I can get the lightweight flywheel as well.
    I e-mailed Scion, they are putting me in touch with thier engineers to get the exact technical specs on some things. Like I wanted to know if the TRD exhaust for the Release Series 8.0 actually had dyno proven HP gains. Also asked about stock flywheel & crankshaft pulley weights.
  7. May 2, 2013 at 11:19 AM
    #167
    tacobell007
    Drew
    Western MA
    Nice. I'm not sure about the second gens, but when researching for an exhaust (didn't want a chainsaw sound) I found out that for first gens the TRD really only adds a deeper tone since it is only an axle back and if there is any gain at all it is minimal to say the least. They said the only way to get more power from exhausts is through catbacks and headers
  8. May 2, 2013 at 11:30 AM
    #168
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  9. May 2, 2013 at 12:25 PM
    #169
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    The TRD on the RS 8.0 is supposedly a Cat-back, still trying to confirm this. Supposedly makes 183 HP instead of the stock tC 180. lol. :woot:
    Their tC gear stops after 2010 :( Only have 1st gen parts.
  10. May 2, 2013 at 5:11 PM
    #170
    tacobell007
    Drew
    Western MA
    Lol well that would be good for you then ;)
  11. May 2, 2013 at 5:34 PM
    #171
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Just went over all the instructions for pulley install. Might attempt this asap...
  12. May 2, 2013 at 5:40 PM
    #172
    tacobell007
    Drew
    Western MA
    I would imagine that it is relatively easy? Take the belt off, unbolt old pulley, bolt up new one and torque it down and put the belt back on?
  13. May 2, 2013 at 5:45 PM
    #173
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, pretty much. And I'll need to coat the new pulley exterior with a light oil.
    I forsee zero complications, I've just never done it before.
  14. May 2, 2013 at 7:05 PM
    #174
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Check to see if you need a pulley puller. The tool can cost quite a bit if I remember correctly. Tis is for a GM pulley.
  15. May 2, 2013 at 9:07 PM
    #175
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    So far from everything I've read, the pulley should be able to be dislodged by hand after the main bolts removed, so I'm going to try without one first. If I'm forced to re-assemble mid-way through the process so be it. :eek:
  16. May 3, 2013 at 3:27 PM
    #176
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Saved for later: Flywheel weights
    Stock is 16 lbs 9.8 oz. Fidanza is 9 lbs 2.8 ounces.
  17. May 3, 2013 at 3:28 PM
    #177
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Just discovered something with all the mess of dealing with henninger in Calgary. The courtesy car getting hit, repairing my tc and them not being able to find the body kit pieces..
    I was never charged for the winter to summer tire swap or the oil change. Boo ya. extra 150$ in my pocket.
  18. May 4, 2013 at 6:17 AM
    #178
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    I bet you already paid for it with al the other charges. ;)
  19. May 4, 2013 at 6:24 AM
    #179
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    a few times over at least :eek:
  20. May 4, 2013 at 6:28 AM
    #180
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    LOL, I understand completley.
