BrokenTusk's D.R.D Build
Discussion in '2nd Gen. Builds (2005-2015)' started by BrokenTusk, Jan 11, 2012.
  1. Jun 5, 2012 at 2:07 AM
    #321
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Tim Hortons commands 76% of the Canadian market for baked goods (based on the number of customers served) and holds 62% of the Canadian coffee market (compared to Starbucks, in the number two position, at 7%).[8]
  2. Jun 5, 2012 at 2:08 AM
    #322
    tacomarotto
    tacomarotto Tempus Fugit, Memento Mori
    Jon
    Jacksonville, FL
    2001 DC 4WD TRD 2022 Lexus GX460
    sounds like starbucks
  3. Jun 5, 2012 at 2:08 AM
    #323
    tacomarotto
    Jon
    Jacksonville, FL
    well there ya go!
  4. Jun 5, 2012 at 2:10 AM
    #324
    tacomarotto
    Jon
    Jacksonville, FL
    alright i gotta shit then sleep.
    finishing my satoshi tomorrow when the mesh gets here in the mail. need to find some sleep somehow
  5. Jun 5, 2012 at 2:12 AM
    #325
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    lol yea I'ma go nap too, ciao!
  6. Jun 5, 2012 at 2:17 AM
    #326
    tacomarotto
    Jon
    Jacksonville, FL
    night man
  7. Jun 5, 2012 at 5:36 AM
    #327
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    Nice job on the replacement HU install.
    One of the things I like most about the Tacoma in the ease in which an aftermarket sound system upgrade is accomplished. Lots of different sources for everything you need and the space in the Tacoma to make it happen.
    The only drawback is the loss of space if you are placing some thump in the mix. But that is true of almost all vehicles when installing a separate bass speaker with enclosure.
  8. Jun 5, 2012 at 5:53 AM
    #328
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I know, and now all I need is the adapter wiring harness which literally plugs right in, then I'll have to install an Aux port somewheres in the vehical. Thinking I might skip doing an Aux though and go straight for a charging Ipod hookup. Be much more beneficial to me in the long run.
  9. Jun 5, 2012 at 6:05 AM
    #329
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Do you have space for the AUX plug above the shifter console?
  10. Jun 5, 2012 at 6:09 AM
    #330
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yes, but I still think I'd rather route it underneat and into the center consol, outta site outta mind. Plus then I can keep my cupholders free. Though the pocket area in front of the shifter isn't a bad idea either, and then it's more easily accessible and no trying to open center while driving.
    hmmm...
  11. Jun 5, 2012 at 6:13 AM
    #331
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    The junk yard could be your friend if you can find out what other Toyota vehicles used the module. Not too many 2nd gen Tacoma's in the JY yet. Another 3 years or so and they will be showing up in the JY.
  12. Jun 24, 2012 at 5:08 PM
    #332
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    June 2012:
    A few months ago someone decided it'd be a great thing to rip out my Radio antenna from my hood, leaving behind half the length of the screw in portion still broken off inside the hole. :mad:
    So I finally got a hold of a 1/16 drill bit and a cordless drill, drilled a slot into the antenna piece still inside the hole and used a flat head screw driver to get the old piece out. Upgraded to a sexy new black "Cravenspeed" Antenna :D
    I noticed I was getting a lot of sideways movement across the idler pulley next to my S/c. It was actually moving slightly off the pulley by a few millimeters then going back on. Over time this had caused a rounding of the inner edge of my pulley and damage to the belt leaving some pieces of belt rubber melted into the grooves of my slotted pulleys. I bought a new belt, new pulley, and used a flat head to clean every groove of every pulley on my engine. Also finally increased from the 76mm Idler to the new 82mm in order to add tension and remove slipage. I wanted an 80mm but they didn't have one.
    Oh well, we'll see how well it works.
    So I'm running the new combo (belt, pulley, cleaned pulleys) for about 24 hours and I lift the hood to check for wear and notice I've got a slight melted groove showing up on the brand new belt.
    After some looking around I discover that another idler pulley on the opposite side of my engine has a fried bearing (probably from the shit and abuse I put it through) and it was overheating causing the belt to get soft. New OEM pulley was 101$
    I ended up returning it because I'm going to get another plastic one to help with heat dissipation.
    And it'll be lighter too :D
  13. Jun 24, 2012 at 7:02 PM
    #333
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So it seems that your bearings in your factory idler pulleys seem to be wearing out?
    Which idler pulley was it that went bad? One of the ones which bolt to the timing cover, or the one that is a tensioner as well?
  14. Jun 24, 2012 at 7:57 PM
    #334
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  15. Jun 24, 2012 at 8:53 PM
    #335
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    The timing cover one has already been replaced, the new one that seems to be over heating is the idler near top right of engine, the flat faced one. I'm going to replace it with a plastic one first, see if it works out. If not, I'll check out your link, thanks! :D
  16. Jun 24, 2012 at 9:06 PM
    #336
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Welcome sir.
  17. Jul 5, 2012 at 5:39 PM
    #337
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Will do, added to my build tred for safe keeping
  18. Jul 19, 2012 at 11:15 AM
    #338
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
  19. Jul 19, 2012 at 9:24 PM
    #339
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Ahahahahahaha!!
  20. Jul 20, 2012 at 4:53 AM
    #340
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    hello my canadian friend, I have a question for you.
    your URD kit uses Liquid to Air intercooling correct?
    where is teh heat exchanger?
