BrokenTusk's D.R.D Build
Discussion in '2nd Gen. Builds (2005-2015)' started by BrokenTusk, Jan 11, 2012.
  1. Jul 20, 2012 at 4:57 AM
    #341
    BrokenTusk
    BrokenTusk [OP] I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Aloha :D
    Right after the discharge of the compressor, the part I labelled with the URD sticker :thumbsup:
  2. Jul 20, 2012 at 4:59 AM
    #342
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    ok the radiator portion then. is there one? like that box is connected to hoses going to a tank then a pump and then a radiator?
  3. Jul 20, 2012 at 5:14 AM
    #343
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, those are the hoses you see coming off the back of it, I routed everything around the left side of the engine bay, down next to windshield wippers, next to headlight, down to lower valence radiator.
  4. Jul 20, 2012 at 5:26 AM
    #344
    Kelson
    Kelson
    Honolulu, Hawaii
    ok so that little radiator, is that an oil cooler?
  5. Jul 20, 2012 at 5:29 AM
    #345
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    ?? If your looking at a front pic, with the little cooler on the top right, then yes that is the S/c oil cooler.
  6. Jul 20, 2012 at 5:32 AM
    #346
    Kelson
    Kelson
    Honolulu, Hawaii
    rajahhh
    yeah that one lol.
  7. Jul 20, 2012 at 5:35 AM
    #347
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, dis one
  8. Jul 22, 2012 at 4:39 AM
    #348
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  9. Jul 22, 2012 at 4:59 AM
    #349
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    July 20th, 2012:
    Blew another damn belt :(
  10. Jul 23, 2012 at 1:56 AM
    #350
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    July 23:
    Ordered 2 more belts and 6 Boost rated spark plugs from URD. Been running the same stock plugs since long before I was boosted, time for my 100,000 km tune up.
  11. Jul 23, 2012 at 6:29 AM
    #351
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    i think its time to go trd and stop blowing belts
  12. Jul 23, 2012 at 6:44 AM
    #352
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Not it the budget at this point, This one will be urd till she dies. Just ironing out all the minor bugs, I'm platueing the build as far as power goes
  13. Jul 23, 2012 at 8:40 AM
    #353
    Darthyota
    Alberta
    Blown BSP X-Runner
    i just dont get why you keep eating belts
  14. Jul 23, 2012 at 10:32 AM
    #354
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    He's a dinosaur
  15. Aug 5, 2012 at 2:58 AM
    #355
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    July 29/2012:
    About a month ago I noticed my passenger side valve cover was leaking oil. Which unfortunately is the side right below all my supercharger components. So I set aside a day to rip it apart at my leisure, all in all only took about 3 hours.
    Before pic, with bypass & belt off:
    It was a good thing I had to do this repair too! With the intercooler off, I found out one of the hoses had been rubbing up against the main wiring harness near the firewall. Thank god I found this out before it cause any damage. It had just finished rubbing through the covering, but not the wiring yet.
    Internals:
    Found the reason it started leaking, slightly mis-shapen factory gasket. You can see the deformation near the corner if you look closely:
    Everything put back together and properly torqued closed, I figured I'd inspect my throttle body for shitz n giggles:
    Completely spotless at 110,000 kms. Joys of having my 7th injector spray on it. Self cleaning!! :woot:
  16. Aug 5, 2012 at 9:56 AM
    #356
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    LMAO!!!
  17. Aug 5, 2012 at 10:01 AM
    #357
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    In this picture, you can see the toyota silicone that is on the gasket itself.
    Where that silicone comes from, is the dab that they place over the seem between the timing cover and the head. It helps to seal with the valve cover on.
    Over time though, it becomes hard, as I am sure you noticed whilst doing this job, and then a leak happens.
    It isn't always necessary to add some silicone back there, but if a leak re-occures, then a little dab will make it all better.
    Throttle body - looks like AJAX was there....lol
  18. Aug 6, 2012 at 11:53 AM
    #358
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Good to know, i noticed the silicone when I had everything apart but the seem imprint into the gasket seemed almost "too much". Hence my factory bad mold idea. I sealed everything back up and havent had an issue yet. *fingers crossed*
  19. Aug 7, 2012 at 9:23 AM
    #359
    forsythfd922
    forsythfd922 Where the hell did that come from...
    Atlanta, Ga
    2019 Tacoma TRD Off-Road
    Nfab Nerf Bars, WeatherTech Tri-Fold Hard Cover, 20% tint, TRD Pro Aftermarket Grill, TacomaBeast aftermarket head and tail lights, Raptor-style grille lights, MBRP Cat Back Exhaust, Air Raid Cold-Air Intake.
    Dude, you have been through the ringer with that truck.... Props for determination...or being one hard headed son of a bitch...either way... :cool:
  20. Aug 7, 2012 at 10:09 AM
    #360
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Thanks :cool: I'm more stubborn then I should be sometimes, but it pays off :D
