Bronze scs on pyrite mica
Discussion in 'Wheels & Tires' started by snook7621, Jan 21, 2019.
  1. Jan 21, 2019 at 6:41 PM
    snook7621
    snook7621 [OP] Member
    2012 pyrite mica access cab
    I'm want to order f5s for my pyrite mica tacoma and can't decide on a color. I've looked through all the scs photo theads and haven't seen a picture of the bronze f5s on a pyrite mica tacoma. Anyone have a picture of this combo?
  2. Jan 21, 2019 at 9:06 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
  3. Jan 22, 2019 at 1:02 PM
    snook7621
    Yeah Ive seen those photos of the gunmetal f5s and bronze sr8s and the bronze sr8s look good. Was hoping to see the bronze f5s before I pull the trigger though.
  4. Dec 28, 2020 at 6:42 AM
    Squatch_Taco
    Squatch_Taco Founder of Team Overland
    Matthew
    Southern Oregon
    2014 Pyrite Mica Tacoma TRD "Squatch Edition"
    Performance: TRD Supercharger :D HP Tune using Overland Tailor Tuning with custom supercharged calibration. Cravenspeed Flex pod with Auto Meter Boost and Wideband A/F gauge. AFE Stage 2 CAI In House Fabrication Stainless Snorkel Aeroturbine 2525XL muffler, with rerouted crossover and chopped exhaust pipe Sierra 4.88 R&P gears for front axle Yukon 4.88 R&P gears for rear axle Power: CBI Group 31 battery cage Odyssey Group 31 extreme duty X2 Power AGM Battery 100W Overland Solar Panel Landstar Solar Charge Controller Redarc Smart Battery Isolator Busman Circuit Breaker Blue Sea aux fuse box (12) Blue Sea aux fuse box (6) Newport Vessels trolling motor smart battery box and power center with usb and DC ports Suspension & Brakes: Icon 2.5 EXT remote reservoir Coil-overs with 14" 700# springs (set at about 2.5 inches of lift) Camburg UCA's w/ moog balljoints Icon EXT VS 2.0 remote reservoir rear shocks Old Man Emu Dakar rear leaf pack Wheelers Superbumps front and rear Extended stainless steel rear brake lines Old Man Emu carrier bearing drop Sway bar delete All-Pro U-Bolt flip Power Stop Carbon Fiber Ceramic Disc Brake Pads Power Stop Drilled and Slotted Brake Rotors Power Stop Rear Break Shoes Interior: Expedition Essentials dash mount Rago Fabrication center console mount w/ Bridge Various RAM Mounts Dorman universal seat heaters Blue Sea Systems 4 volt dual USB port wired to constant power Weathertech (black) floorliners front and rear Bird Dawg industries rear view mirror riser Molle visor organizer OEM door sill protectors Salex console organizer Liviqily molle sun visor organizer Wet Okole seat covers front and rear (black) LED Map and Dome lights Kenwood Excelon DNX695S Double Din JL Audio C3 front door speakers JL Audio C2 rear door speakers JL Audio Stealth box w/ 1 10" sub Kenwood Excelon 5 channel 800w amp Navigation: Garmin inReach mini iPad mini 5th Gen Earthmate GPS App Gaia GPS MotionX-GPS Exterior: Outer Tents Osprey Slimline Aluminum rooftop tent Snugtop Rebel Sportsman Canopy Prinsu Cabrac Prinsu Top Rack Debadged Cravenspeed Stubby antenna Mud flap delete OEM bed mat "Hi-Lift" - Hi-Lift mount Color matched Satoshi grille from TW member StealthTaco BAMF bed tie downs 15% Tint on all door windows "Custom" trail pinstriping CVT 55" Summit Series awning in grey Cut fenders to clear 35’s Auto Ventshade Window Deflectors Lighting: AlphaRex USA 880752 Nova Series Full LED Projector Headlights Rigid SR 20 inch light bar Rigid Dually floods OTRATTW switches LED license plate lights Aurora Diffused 40w pods in rear bumper Wheels/Tires: (5) BFGoodrich Mud Terrain T/A KM3 35X12.5r17 (5) 17x8.5 SCS Ray 10's in matte dark bronze 4.30 BS Armor: BAMF Sliders w/kickout (weld on) Pelfreybilt steel plate bumper with center hoop and fog/LED bar cutouts Brute Force Fab High Clearance rear bumper (custom length side pieces) with swing out and double Jerry can holder and C4 Fabrication rear camera relocate Pelfreybilt steel IFS skid Pelfreybilt steel Mid skid Pelfreybilt steel T-case skid Recovery: Warn 9.5xps winch and Factor 55 1.0 Hawse fairlead Factor 55 Flat Link Warn Medium-Duty Epic Recovery Kit Misc ropes/straps Fiskers Axe Hults Bruk Axe 48" Hi-Lift Jack Hi-Lift Jack and Quick Fist Shovel Mount Fiskars Steel Shovel MaxTrax Boards and Mount ARB tire repair kit Smittybilt receiver hitch shackle Coms: Yeasu FTM-400DR Dual Band Ham Radio Uniden 510XL CB 3ft (offroad) and 2ft (in town) Firestik Tram 140MHz-170MHz + 430MHz-470MHz Dual Band NMO Antenna Baeofeng Handheld 2m radio Relentless Fab Passenger side antenna hood mount Relentless Fab driver-side antenna hood mount Misc mods: 12volt.solution Remote Starter DFG-Offroad fridge slide SnoMaster fridge Prinsu Fill Plates repurposed to mount fridge Gear Tech Customs wheel well liners Diff breather extension (behind taillight) Seat belt beep disable Door lock/Unlock beep disable ARB CMKA12 Onboard air compressor under the hood ARB inflation kit Anti-Dark underhood lights Redline QuickLift Plus hood struts Locker anytime mod Black "Team Overland" Trasharoo Big cab mount chop BFH massaged pinch weld Trimmed fender flares ECGS diff bushing Headliner patches #EAF CaliRaised Bedside stiffeners
    Not sure if you found them yet, but...
    Edit: I don’t read good. These are the Ray10’s in dark bronze...
  5. Dec 29, 2020 at 12:29 AM
    Yodastacotruck
    Yodastacotruck Well-Known Member
    2021 MGM 4x4 trd off road
    Stock
    That’s clean
    Squatch_Taco[QUOTED] likes this.
  6. Dec 29, 2020 at 5:02 AM
    Squatch_Taco
    Matthew
    Southern Oregon
    :cheers:
