Brown goo in radiator
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5000fingers, Feb 24, 2018.
  1. Feb 24, 2018 at 3:42 PM
    5000fingers
    5000fingers [OP] Well-Known Member
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    '95 Tacoma V6, roughly 200K miles.
    After replacing the radiator recently, I've been hearing bubbles and steam coming from the heater core behind the dashboard when I'm accelerating. And there's a bunch of brown gunk in the coolant. There was some brown gunk in the old radiator, but I assumed it was because the radiator was old and gunked up. But maybe not, maybe there was a separate issue apart from the radiator being old and leaky.
    What's likely going on here? Please tell me I don't have a manifold gasket leak. And if I do, please tell me that I can do it myself without taking the engine out, and that I can safely drive the car until the summer before I get to it...?
  2. Feb 24, 2018 at 4:05 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Brown Gunk? I'm sorry man that's almost certainly some kind of oil in the coolant. Can you take a picture?
    nickj604 likes this.
  3. Feb 24, 2018 at 4:06 PM
    4drtaco03
    4drtaco03 Well-Known Member
    BAY AREA
    2003 TRD/ 2004 / 2019 SR5 4x4… now awd sprinter
    Did you do a full coolant flush?
  4. Feb 24, 2018 at 4:13 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Sounds like a typical head gasket leak to me. But you can make sure it is bled properly first by parking with the nose uphill and letting it warm up fully with the rad cap off, then put it back on once it has reached operating temp.
    Dalandser likes this.
  5. Feb 25, 2018 at 9:44 AM
    5000fingers
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    I'll see about bleeding it properly, but that wouldn't create the brown gunk, would it? There's just a bunch of brown gook right around where the radiator cap is. It's sort of solid-like, it doesn't look like how I imagine oil in the coolant would look, which I've heard described as looking like chocolate milkshake.
    If this is my head gasket, how urgent is it that I fix it? Can I limp along for another thousand miles before I get to it?
    And can this repair be done with the engine still in the car?
  6. Feb 25, 2018 at 9:56 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Let's say it is a head gasket leak. You would not need to remove the engine from the truck, I can't imagine a repair (besides actually rebuilding the engine) that requires removing it entirely.
    I would run a compression test and confirm it's a head gasket leak. If it is, driving it would stress the engine even more and you will eventually destroy it if you let it keep going and going.
  7. Feb 25, 2018 at 10:58 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    headgasket issue or not, this is not normal and there definitely is a problem
    I would fix it ASAP because when you let problems sit, that's when they become bigger and worse
  8. Feb 25, 2018 at 11:01 AM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Think about the only place coolant can come in contact with oil. Now think about how thick oil is and what it would look like if it came in contact with coolant. If you don't want to believe us take some oil and coolant and put it in a container and shake it and look for yourself.
  9. Feb 25, 2018 at 11:18 AM
    Speedytech7
    Even if it is just combustion gasses escaping into the coolant (which happened to me) you'll get nasty brown coolant and constant bubbling. My head was cracked though
  10. Feb 25, 2018 at 11:18 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Do a compression test to quickly figure out if you have a blown headgasket. If you don't have a bhg, you can flush the coolant - if you mixed green and red coolant it can gunk up.
  11. Feb 25, 2018 at 11:32 AM
    Speedytech7
    I'd do a leakdown test, compression may show an issue but chances are if it has been running okay it is a small leak and compression won't necessarily reflect that.
  12. Feb 25, 2018 at 11:45 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Sure. Chances are one of the heads is coming off...
    I blew a hg and had a good bit of gunk in me coolant.
    Next time replacing a radiator OP make sure to flush the coolant completely and make sure to only use one kind of coolant - red vs. green vs. orange. It sounds like you could have two different issues - air in your coolant system and a bhg if you already saw similar stuff in your coolant - leak down test equipment can be rented for free from parts stores...
