Brown residue near alternator??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 22Coma6MT, Sep 13, 2023.
  1. Sep 14, 2023 at 5:02 PM
    #41
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    you've found the long lost Rust belt, you're gonna be famous
  2. Sep 14, 2023 at 5:27 PM
    #42
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    In the photo showing the upper radiator hose, why is the clamp mark on the hose, and the clamp, in different locations? Has the upper rad hose been removed for some reason?, is it slowly leaking coolant water on the belt? Have you checked to see if the belt is wet just after a drive long enough to get the coolant up to temp?
  3. Sep 14, 2023 at 5:40 PM
    #43
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Disregarding the dust buildup, Just here to say I have a 2018 and my belt is still original and it’s black… I don’t know all the ins and outs of drive belt construction but it looks likes somethings up with the belt. I’d remove and replace belt and give the idlers a spin and see how the bearings are doing. Does the brown stuff wipe off the belt?
  4. Sep 14, 2023 at 5:56 PM
    #44
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    still under warranty, take it in
  5. Sep 14, 2023 at 6:54 PM
    #45
    Toyko Joe
    Toyko Joe Here for the pictures
    Just think of it was the alternator how would it apply the red residue on the outside surface of the belt???? :goingcrazy:
  6. Sep 14, 2023 at 7:17 PM
    #46
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
  7. Sep 14, 2023 at 7:34 PM
    #47
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    It’s a Toyota, everything you place on or in it will rust.
  8. Sep 14, 2023 at 7:35 PM
    #48
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    :rofl::rofl::rofl: So true :rofl::rofl::rofl:
  9. Sep 14, 2023 at 7:44 PM
    #49
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    ok mr engineer why dont tires rust
    soundman98 and Phlogiston like this.
  10. Sep 14, 2023 at 8:03 PM
    #50
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    I don’t know ha ha
  11. Sep 15, 2023 at 5:21 AM
    #51
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    He's a belt engineer, NOT a tire engineer. BIG DIFFERENCE! :rofl:
    soundman98 likes this.
  12. Sep 15, 2023 at 5:39 AM
    #52
    lbhsbz
    lbhsbz Well-Known Member
    Bearing is shot…take the belt off and spin it to confirm.
    faawrenchbndr, danny15l and RIX TUX like this.
  13. Sep 15, 2023 at 5:51 AM
    #53
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I am in the idler pulley camp. What are your driving patterns? Does the truck regularly sit for a few days without being driven, or has it sat for a longer period of time? Surface rust may form on the idler pulleys (like it does on the surface of brake rotors after just a couple of days) and then transfer to the belt. I would change the belt and clean stuff up. Actually, I'd probably just clean stuff up and not worry about it unless the belt started deteriorating or I heard some funny noises.
  14. Sep 15, 2023 at 6:21 AM
    #54
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    :D:D:D
  15. Dec 2, 2023 at 7:06 PM
    #55
    whitetiger
    whitetiger New Member
    Dale
    My 2019 Tacoma with 90,000 miles looks exactly like that. From research I have done it is grease leaking out of the worn out bearings on the idler pulleys or the belt tensioner. Just checked mine and they all need replaced. Not to the point of a squeaking sound yet but all have a slight back and forth play in them. Looking close at the belt on idler pulleys when engine is at idle the belt has slight back and forth movement.
  16. Dec 2, 2023 at 7:15 PM
    #56
    Phlogiston
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    From what i understand from previous comments on this forum, those idler pulleys are supposed to have some play/wobble in them, working as intended.
  17. Dec 3, 2023 at 4:26 AM
    #57
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I’ve never seen a belt rust. I have seen pulley and idler pulley rust.
  18. Dec 3, 2023 at 4:44 AM
    #58
    22Coma6MT
    22Coma6MT [OP] Well-Known Member
    2022 TRD Sport AC 6MT
    UPDATE: I did take it to the dealer and they said this is fairly common. Some vehicles/belts do this, others do not according to them. It does not affect the performance or longevity of the belt and they would not replace it.
    There are no fluid leaks anywhere, unusual noises (other than rattles from the dash and door panels), and the truck is used every day of the week. The truck does not go off road other than an occasional gravel road and is well maintained.
    I am not sure I believe them but I do not have the time or patience to press the issue with them any further or to get Toyota Corporate involved. I do not have another dealer within 150 miles so going to another dealer is not an option.
    The condition of the belt looks good otherwise, and the pulleys seem fine with no unusual play or noise. I have purchased another belt and plan to replace it.
  19. Dec 3, 2023 at 4:44 AM
    #59
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    X2...
  20. Dec 3, 2023 at 4:52 AM
    #60
    22Coma6MT
    although it appears to be a clamp mark, that is not a clamp mark on the hose. the clamp has never been loosened and moved. it is a water mark on the hose from when i washed the truck.
