Brush guard and Winch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nerwinski, Jan 6, 2025.
  1. Jan 13, 2025 at 9:33 AM
    Pigpen
    Dan
    Northwest Montana
    A hidden front hitch or winch mount will replace the structural bumper mounting points. Then you mount the cosmetic bumper to that. A "brush guard" should mount separately, and not interfere in any way.
    I've had my front hitch for most of the truck's life and winch often for my work (forestry/ tree work). Being able to remove the winch when you don't need it is really nice.
    Nerwinski[OP] likes this.
  2. Jan 13, 2025 at 3:19 PM
    TacoTuesday1
    SD CA
    ARB is just one of the few steel front bumpers that have full hoops, and possibly the only one that can be picked up at a store the next day.
    their crash safety means they’re simply the only one that burned money on testing.
    they have numerous downsides.
    1. It’s not the lightest
    2. It’s not the best approach angle
    3. Not the best looks
    4. Custom brackets needed to fit lights that aren’t theirs which aren’t the best
    5. It’s designed for a 265/70r17 which makes no sense at all and means it requires additional work to clear a truck tire adding cost
