Brush Guard Install 97’ Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by dnevels, Feb 3, 2021.
  1. Feb 3, 2021 at 2:14 PM
    dnevels
    dnevels [OP] Active Member
    Daryn
    Henderson, TN
    97’ Tacoma SR5 Xtracab
    Hoop steps LED tag light assemblies
    I just recently bought this Tacoma off of a buddy of mine and it came with this brush guard. However the guard doesn’t have any marking to tell me what brand it is so I have no idea how to install it or if I’m missing any parts from the front end of the truck as well. Need to know what parts I’ll need and directions on how to install if anyone can help! Thanks!
  2. Feb 3, 2021 at 2:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    To be honest, you’ll probably get a better idea by actually holding the guard up to the truck and seeing how it “fits”. You and a buddy can hold it up and see. Or use some jack stands if you are by yourself.
    It’s probably only going to go on one way.
    You’d think it would be fairly obvious when you “get close”.
    Use some under towels zip tied to the metal bars to keep it from hitting the paint.
  3. Feb 3, 2021 at 2:28 PM
    dnevels
    Daryn
    Henderson, TN
    It doesn’t have a front bumper or front valence. Do I need that to install the guard? Also doesn’t have the bumper mount brackets so I wasn’t sure if it will actually attach.
  4. Feb 3, 2021 at 2:33 PM
    TnShooter
    Deogee
    STOCK
    I have no idea. The picture of the brush guard looks likes it upside down.
    If you hold it up there and there is nothing to bolt to, you’ll need parts. Or a metal fabricator.
    (Or a friend that knows how to weld)
    dnevels[OP] likes this.
  5. Feb 3, 2021 at 3:57 PM
    dnevels
    Daryn
    Henderson, TN
    Ok I appreciate the insight. Any idea what brand it is?
  6. Feb 3, 2021 at 4:47 PM
    ben20004x4
    ben20004x4 Well-Known Member
    TAMU
    2000 SR5 130k miles
    Looks a little bit like Trail Gear or a Coastal Off Road kit, not sure the model names tho
  7. Feb 3, 2021 at 6:47 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    There are holes for bolts in the crush cans at the end of front frame main members.
  8. Feb 3, 2021 at 7:39 PM
    dnevels
    Daryn
    Henderson, TN
    So do I need to have a front bumper and front valence panel in order to cover the a/c condenser or do I just mount it to the front and leave all that open?
  9. Feb 3, 2021 at 7:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Have you not tried what others have told you?
    If you hold the bumper up against the rig, you'll see where the frame horns are used as @Black DOG Lila suggested.
    The metal bar is what attaches to your frame horns and then that to the bumper.
    I'm going by my own theory as I have no idea what bumper that is but it looks crazy easy to figure out.
    To answer about the rest of the stuff, it's just left exposed.
    Google aftermarket bumpers on a 1st Gen Tacoma, then click the images tab.
    Wyoming09 likes this.
  10. Feb 3, 2021 at 8:53 PM
    dnevels
    Daryn
    Henderson, TN
    Yeah see what they are saying. Probably just overthinking it honestly. Just have to put all the pieces together. Thanks for the advice and heads up.
  11. Feb 3, 2021 at 9:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    All you're missing are these pieces, even then they're removed for aftermarket bumpers-
    dnevels[QUOTED][OP] likes this.
  12. Feb 3, 2021 at 9:27 PM
    dnevels
    Daryn
    Henderson, TN
    Got it! Thanks for the help!
  13. Feb 4, 2021 at 7:00 AM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Welcome to TacomaWorld!
